Results 1 to 4 of 4
Thread: KL-34GH101 10:1 Gear BOX problem.
    Silver Member diyengineer's Avatar
    Feb 2010
    USA-WA STATE
    Exclamation KL-34GH101 10:1 Gear BOX problem.
    The units looks amazing, very beefy and well made.
    The only problem is the 2 set screws that couple the servo shaft with the gear box are NOT tapped through all the way!!! Leaving the gearbox useless until the threads are tapped through all the way.
    Anyone else run into this problem? I bought 2 of them and they both wont thread. They thread till they are barely flush with the inside cylinder but wont penetrate into the inside of the cylinder and apply pressure on the servo output shaft...
    I basically just need to run a tap through there and finish the job. TO do this i will have to take the back of the casing off because the tap wont be long enough.. Will it all fall apart?
    Attached Thumbnails Attached Thumbnails KL-34GH101 10:1 Gear BOX problem.-imag0381_1_.jpg
    Feb 2010
    USA-WA STATE
    Got it.
    Here are some before and after pictures. Had to use a M6x1.0 die to clean up the threads on the knurled threads. Then used a M6x1.0 Tap on the holes to finish the job. Now the problem is my huge servos don't have 2 flat 90 degree faces. I bought these servos from keling, there the largest he offers. They have a single keyway. I will have to use a die grinder to grind the 2 flat surfaces. the amount of TQ and power the servos deliver, they would spin the set screws without proper flat surfaces.
    Attached Thumbnails Attached Thumbnails KL-34GH101 10:1 Gear BOX problem.-.jpg   KL-34GH101 10:1 Gear BOX problem.-tools.jpg   KL-34GH101 10:1 Gear BOX problem.-.jpg
    Aug 2008
    united sates
    O.M.G......Bet it took longer to take the pics and post the message than it did to tap to holes and flat a shaft.......
    Feb 2010
    USA-WA STATE
    Well for $550 dollars in gear boxes, and $600 and servos i should not be doing tapping, boring, upgrading setscrews, and flatting shafts.
    On there website:
    "It will work with our NEMA 34 motors"
    Oh sure it will work (correctly) after some minor upgrades. The stock setscrews, you can't apply any pressure to without stripping the flat pot metal heads.I took them back out an cut down metric socket caps so i could really crank them down and use loctite. To put them in though since the heads were bigger you have to bore the access holes larger to fit them through. Then double flatten the shafts.
    You drop $1100 dollars and let me know how you feel. Quick fix, but annoying. Just thought i'd help anyone else out in the same boat.
  1. Basic Bevel Gear - Milling a valley for gear teeth
    By ngr1 in forum General CAM Discussion
    Last Post: 04-05-2012, 10:55 AM
  2. Need a Lagun Lathe Gear or Custom Gear Maker
    By douglasco in forum General Metal Working Machines
    Last Post: 01-12-2011, 09:54 AM
  3. Gear slipping problem ????
    By twocik in forum Mini Lathe
    Last Post: 12-19-2008, 03:58 PM
  4. Newbie- Space Gear 48 serial Communication Problem
    By stanley66 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-28-2008, 08:38 AM
  5. Gear Teeth thickness problem.
    By nikolatesla20 in forum Mechanical Calculations/Engineering Design
    Last Post: 08-09-2005, 02:39 PM
