Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 04-18-2010, 01:13 PM
octothorp is on a distinguished road
stalling on Keling setup
I feel like I've tried every possible combination of settings to get my Keling setup working, and I still get frequent stalling and grinding.
I've got:
C10 Parallel board
3 KL4030 drivers
3 KL23H2100-30-4B (382 oz) motors
KL-320-36 power supply
I've tried both setting each axis to 800 SPI with the microstepping set to 1, or 6400 SPI with microstepping set to 1/8. I've got the current set to 3.0. I've tried every possible combination of direction and step pulse. I get an almost passable accuracy when I set the speed really low (one inch per minute), but it still grinds roughly every 1/3 of a turn. At higher speeds, like 20 inches per minute, it will have longer smooth stretches, but the grinding and stalling will also last longer when it occurs. If I try a speed like 60, it stalls for almost the whole cycle.
This grinding and stalling occurs regardless of whether my motors are hooked up to the lead screws, or just running on their own. It happens with all 3 motors.
In trying to diagnose the problem, I've noticed that when I send a G0 command in Mach3 and then watch on the diagnostics screen, the buffer value is typically at 3%, but will shoot up to about 12% when the stalling occurs. Unfortunately, I don't have enough knowledge to understand what all of this means, and what I can do to fix it. Any suggestions would be greatly appreciated.
Old 04-19-2010, 02:26 AM
elmerfud is on a distinguished road
um, I think 382oz motors are rated at 2.5 amps?
the higher current setting would give the wrong 'chopping' effect, if it has any.
i think the 1/8 or 1/10 stepping would smooth it a little, less amps, more voltage, the motor tuning in mach 3 usually likes .3 microsecond points on the motortuning (.3off,.3on,.3off).
You could spend a whole evening trying the settings with the motor on a bench, you'll get it soon enough.
Old 04-19-2010, 02:48 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
YouTube- 65 ipm
Do a search on stepper dampers.
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Keling 5056 driver setup alexccmeister Automation Technology Products 9 04-19-2011 10:28 PM
oh no only my y axis keeps stalling stk2008 General Electronics Discussion 44 09-25-2009 05:09 PM
stalling problem cxixer Stepper Motors and Drives 14 10-27-2008 09:47 AM
Stalling Steppers mrscheider Benchtop Machines 20 01-30-2008 02:10 PM
motor stalling planescott Mechanical Calculations/Engineering Design 11 05-05-2006 09:50 PM
