Go Back   CNCzone.com-The Largest Machinist Community on the net! > Commercial Products Support Forums > Automation Technology Products
Automation Technology Products Discuss Automation Technology Products here.
Old 04-10-2010, 09:39 AM
csmoak25 is on a distinguished road
C10 with KL4030 driver wiring instruction for Newbies
I had alot of problems understanding the wiring diagrams so after I got my hooked up I thought I would post it on here. I had to have help from someone who spent at least 5 hours on the phone with and couldnt of done it without him, thanks Jeff
KL 4030 to C10 BOB wiring
X Axis or however you want to do it
Take a short piece of wire and connect the PUL + to the DIR +
Add another wire in the DIR + and connect it to the COM pin on the BOB
PUL- goes to 2 pin on BOB
DIR- goes to 3 pin on BOB
Y Axis
PUL- goes to 4 pin on BOB
DIR- goes to 5 pin on BOB
Z axis
PUL- goes to 6 pin on BOB
DIR- goes to 7 pin on BOB
If you dont have an E stop swith, take a short piece of wire and connect the 10 pin to 5volt next to it.
Jumper setting
COM Jumper is set to pins 2 and 3
Pins 2-9 jumper set to pins 1 and 2
In/out jumper set to pins 1 and 2
You will also have to run a ground wire from you 36 volt power supply to BOB ground where you hooked up the 5 volt supply to it.
If anyone needs anymore help feel free to contact me and I will do my best,
Old 09-27-2010, 02:00 PM
Mogal is on a distinguished road
I made this up a couple years ago now LOL...
Just reinforces what you've wrote... I like pictures
Need Help!- Wiring KL4030 with DB 25 csmoak25 Automation Technology Products 11 03-04-2010 08:58 PM
Driver wiring help needed API tommy23t Stepper Motors and Drives 0 12-08-2009 08:37 PM
Newbie- Wiring Steppers w/o driver board? LowIQGenius Stepper Motors and Drives 7 04-29-2009 08:57 AM
No motion from project using KL4030 driver Delanoman Machine Problems, Solutions , Wireless DNC, serial port 9 02-01-2009 11:38 PM
OMS driver wiring help. cnc2k General Electronics Discussion 6 12-25-2004 06:11 PM
