Results 1 to 6 of 6
Thread: KL-DB25 BoB and Gecko G251 5v help
    Dec 2005
    Hoping someone can help me here.
    I have many 5v wall power supplies, I plan to use one for the 5v needed on the Keling BoB but eveyone of the 5v power supplies I check the output voltage on runs 5.5ish volts.
    Can I still use one of the wall adaptors for my BoB and will the .5 extra volts hurt anything more over hurt my G251's?
    Also is there a amp min for the 5v?
    Thanks for any help.
    Eric
    Theres a good side to every bad side, you just have to look around the corner.
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Thumbs up
    Dbtoutfit,
    1 amp should be more than sufficient.
    5.5 volts wont hurt anything, make sure it is D.C.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Dec 2005
    Thank you,
    I was starting to worry.
    K will I guess its time to hook the 5v to it, close my eyes and hit the power button.
    Nerves are on edge.
    Eric
    Dec 2005
    Well got everything hooked up.
    Measured 5 times cut once so to speak.
    Turned everything on, no dice.
    Motors sounded to lock up but no movement, all output pins are correct.
    is the 251 suppose to have a red light come on when powered?
    I don't have any low active step or directions checked in Mach 3 on the output pins 2-7.
    My DB25 BoB is not the new version with the jumper pins.
    The manual on their site is for the new BoB.
    Do I need to run power to the other Gnd and VCC terminal?
    Also when i first hooked the parallel cable in the BoB, it had a green light that came on, now it only comes on if the 5v supply is on.
    Someone help please.
    Very worried
    Eric
    Dec 2005
    I got it.
    Had to turn on active low and change Estop from 1 to 0.
    I also turned off pins 14 and 16 that I was using for the xylotex board.
    I had no idea what I was paying a little more for but took everyone's word on getting some gecko drives.
    Let me say that NOW Im in the know!
    My feedrate is blistering!
    Before I switched out boards I had the xylotex setup in mach for the fastest feedrates I could get. Just real quick (without step tuning) I clocked over 700IPM!
    Time to get some chips flying!
    Eric
    Dec 2005
    After step inch setup, I'm getting well over 400IPM rapids.
    I didn’t go that high cause I could care less to run them over that speed. Settled with 320ipm.
    One thing to note and before I say this I need to point out the PSU has been making a slight buzzing sound for some time now (year or so it started).
    The PSU I got with my first Zylotex board (4 years ago) took a dump on me today. After doing a few things I turned the system on and everything came up and then all the red lights went out on the 251 geckos, I about **** my pants fearing the worse but after checking the output voltage on the PSU I only had 4volts.
    Luckily I had a backup PSU hooked it up and everything fired back up fine.
    Which brings me to a question.
    What amp PSU would you guys say is typical for 3 269oz steppers 2.8A Phase with the G251's?
    Eric
    1. Motor monster green de probotix con el driver gecko g251
      By Dimebag_cnc in forum Spanish CNCzone
      Last Post: 02-01-2009, 11:32 AM
    2. PCMCIA to DB9 to DB25
      By adda in forum Machines running Mach Software
      Last Post: 05-29-2007, 09:04 PM
    3. 25p IDC to DB25 parallel
      By pzzamakr1980 in forum General Electronics Discussion
      Last Post: 11-15-2006, 08:08 PM
    4. USB to DB25
      By wrloveyuelin in forum Mach Software (ArtSoft software)
      Last Post: 10-23-2005, 12:45 PM
    5. DB25 connector
      By TigerPilot in forum Stepper Motors and Drives
      Last Post: 03-20-2005, 05:06 PM
