You don't have a manual?
What is the make of the VFD?
Hey guys need some info to get me started. Kl-vfd15 I can't seem to get it working. I have power, and have a Flashing display of A5R 1.0 5 could be a "S" but not sure. Only button that work's from here is the prog button, which then give's me flashing PD000, press prog again then i can use the arrow up and down buttons to change PD value. I can use the button >> to change digit postion and then arrow up down buttons, and that's it.
Is their a combination of buttons together to push? don't know what the Jog button is for either. In info to enlighten me would be great.
Ray
Afraid not didn't come with a manual, although i was sent a pdf file, after i sent a message to keling support, but that's not helping me, it talks about pressing Enter, will this unit doesn't have Enter. So i guess the pdf file is genric.
For the make of the VFD have no idea, it only has KL1500 stamp on the front.
Ray
Ray,
Does this look like your VFD?
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
No it doesn't look like that. Where you have F/R button, mine is a Jog Button. Where you have a Enter Button, mine is a Set Button.
Also only my Power light come's on, the other's haven't come on at all as yet.
Ray
Ray,
I believe this is the model you have.
Ray,
Here is the setup documentation.
Jeff...
Jalessi, thank you for VFD file it will be alot of help further down the track. But I really don't understand why, I can't progress any further than i have. Except for pressing the "Set" button and the Arrows up & down buttons i can't enter any other information into VFD. Pressing the other buttons don't have any effect on the unit. I had assume at factory settings the spindle should work, but it doesn't, I simply can't get passed a flashing digital readout. Am i missing something here??
Ray
If you bought this new, I am surprised if you did not get a manuf. manual?
All the VFD's I have worked on, a flashing display usually means there is an error of some kind or that something illegal operation is being performed?
jalessi,
I am looking for a manual on how to set up my KL-VFD15 as well. The Zip file you posted, is that for the HY02D223B model VFD? or is that for a KL1500VFD?
raysul
How have you wired the input terminals, can you do a photo
Mactec54
thank you so much! We are in the process of setting our table up now.
dcolo
What is the spindle Hz 400 or Hz 300 & the spindle motor Amps, Post these to numbers, & I will post all the settings you need
Mactec54
