steps/mm seems really high and steppers get hot.
Results 1 to 7 of 7
Thread: steps/mm seems really high and steppers get hot.
    May 2017
    Default steps/mm seems really high and steppers get hot.
    Im getting my lathe dialed in. When I was setting up the lathe getting the steps dialed in to get my z to read correct my steps have to be 10275 and my x is 12795, this may be acceptable but it just seems really high compared to what other ones I see. The other thing is the steppers seem to get really hot when just sitting idle. I'm sure there is some setting Im missing in mach 3 or i got the wrong type of steppers.
    These are the ones I'm running: https://www.automationtechnologiesin...23h2100-35-4a/
    Member awerby's Avatar
    Apr 2004
    Default Re: steps/mm seems really high and steppers get hot.
    If you're using micro-stepping and inches, then those values are probably correct. No matter what the steps per unit are, that shouldn't affect the heating of the motor at rest. Steppers often run fairly hot (uncomfortable to touch), but if yours are really smoking you might need current-limiting resistors at the drives to keep them down to the rated 3.5 amps.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    What drives are you using, and at what voltage? Do you have the current set correctly?
    UCCNC 2017 Screenset
    May 2017
    Quote Originally Posted by awerby View Post
    How would I know if its set to micro step would that be a setting in mach 3
    May 2017
    Quote Originally Posted by ger21 View Post
    I'm using geckos g540, I don't currently have any current limiting resisters in im still trying to locate some 3500 ohm units
    Mar 2003
    Shelby Township
    That's why the motors are getting hot.
    The G540 is fixed at 1/10 microstepping.
  7. #7
    May 2017
    Ok that makes sense then why I was trying the math and it was only moving .250 before. I ordered some resistors today, it will be Wednesday before I'm back at the shop to put them in. Thank you both for the insight.
