Need Help! "peak current" or "reference current" configuration
Results 1 to 3 of 3
Thread: "peak current" or "reference current" configuration
    Apr 2015
    Question "peak current" or "reference current" configuration
    Hello
    I bought three KL23H286-20-8B motors, they are connected to SainSmart ST-M5045 (2M542) drivers and a 36V 11A power supply.
    I need help to configure the amperes of the driver, the motor says 2.8A current in parallel bipolar configuration, the driver has two data to configure the amperage one is "peak current" and the other "reference current". Do I have to match the "peak current" or "reference current" configuration to the 2.8A of the motor?
    What is the normal working temperature of these motors? for example, after working 2 continuous hours, what would be the normal working temperature?
    Please help...
    Thank you very much.
    MOTORS: https://www.automationtechnologiesin...l23h286-20-8b/
    DRIVERS: https://www.sainsmart.com/collection...r-motor-driver
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: "peak current" or "reference current" configuration
    Use the peak current.
    Temperature can vary greatly, depending on a variety of factors.
    Range can be from slightly warm, to too hot to hold onto. At 36V, I'd just expect warm.
    UCCNC 2017 Screenset
    Dec 2003
    I assume they mean continuous torque (current) for 'reference current' as opposed to Peak (torque) current that should only be experienced briefly without destroying the motor.
