Proximity sensor wiring
Results 1 to 4 of 4
Thread: Proximity sensor wiring
    May 2009
    Default Proximity sensor wiring
    Please excuse my limited electronics knowledge in advance
    I am trying to wire 6 SN04-N NPN NO 10-30v proximity sensors to this KL-1212 breakout board ( https://www.automationtechnologiesin...face-breakout/ ) to serve as home/limits on a cnc router I am building. There are a few threads about wiring 12v sensors and 5v boards but I am still not quite 100% confident and do not want to fry anything.
    After doing a lot of reading on this AFTER I purchased them I have come to realize that I probably should have got NC sensors for fail safe operation and that proximity sensors do not necessarily simply hook up straight to the inputs depending on various voltages etc, but at this point they are installed and all the cables routed in my machine so I figure I will see If I can get them working. I have up until now used mechanical limit switches on other builds which are pretty simple.
    The KL-1212 board I am using does not appear to have a full manual, just basic pinout and wiring diagrams so I am not 100% certain about the specs of the inputs but they measure 5v when the board is on.
    The second problem is that I am not 100% certain if the sensors have internal pull-up resistors or not from the specs, but they do measure 10k between the +v and signal (brown and black) wires so I assume that means they have an internal 10k pullup resistor..? Is this correct?
    Anyway, I have wired up more or less like the diagram attached that was supplied with the board except that I was going to split the 6 limits into 3 pairs, with the pairs each wired in parallel, then each of the 3 pairs then wired to separate inputs on the board for x, y, z and operate them as shared home and +/- limits for 3 axis in Mach 3. The drawing shows 3 limits all wired to one input.
    I have not connected the sensor outputs to the board at this point as I am not sure if I need to use resistors or perhaps relays to avoid frying anything. If I understand what I am reading correctly I should not simply hook the output wires from the sensor to the input on the board due to the 12v sensor and the 5v board and the fact that the sensors appear to have 10k pullup resistors internally? correct?
    The board is powered with a 24v switching supply and there are 5v and 12v taps. The inputs measure 5v when the board is on. I am using the 12 v tap for the proximity sensors
    Would one of you kind souls help walk me through wiring them up so I do not blow up my board?
    If I do need resistors can you help with values and how I would wire everything up with the 3 pairs of sensors to 3 inputs layout I want to try (assuming that seems to be a logical way to hook them up that is, other suggestions would be considered)
    thanks in advance!
    Attached Thumbnails Attached Thumbnails Proximity sensor wiring-kl1212-breakout-board-wiring-diagram-pdf
    May 2015
    Default Re: Proximity sensor wiring
    I'd be surprised if your prox sensors have built in pullup resistors. I'm using 2.2k pullups on prox sensors in my 24 volt system on the manufacturer's recommendation..
    You will need something to convert voltages. There are some signal chip solutions that do the trick. I looked on another forum for the part as it was mentioned recently but couldn't find it. Maybe you could use something like this which I found on a quick Google
    Rod Webster
    www.vmn.com.au
    Jul 2005
    The board description shows to have opto inputs. That means you need to pull it low (to GND ) to trigger it. It has internal current limiting (pullup) to keep from burning ou tthe Opto . You first need to make sure the external (36V) voltage GND is the same as the input GNDS. If so you should be able to turn on an input (as can be seen in the MACH Diagnostics tab and INPUT STATUS) by shorting between an input terminal and the GND. If that works then all you have to do is make the OUTPUT of the Sensor pull to its GND pin (go low) which is tied to the same common GND . The output of the sensor is probably Open Collector. Normally you need a pullup if you want it to change the output pin BUT the Input of the BoB should do that for you. It will limit the current though the opto and provide the pullup. It won't hurt to have a pullup to the +12 bus if you want to measure the action of the sensor with it not connected to the Input .
    The NO version is your best bet . NC are PNP devices and harder to make work.
    Dec 2017
    I'm not sure if this was ever answered or not but I figured I would give a quick solution if none was ever found. I have a similar setup and had a similar problem. What you can do to protect your BOB from the 12v that's on the proximity sensor signal when not sensing is simply wire in a diode inline with the signal wire. Basically use a leaded diode terminated in your BOB P13 (or whatever pin you want) with the stripped end of the diode facing your signal wire from the sensor. solder the signal wire to the stripped end of the diode and it should work just fine. Diodes allow current to flow in only one direction. What will happen is that your BOB has voltage on pin 13 trying to go to ground. When the proximity sensor is not sensing (NO), it has 12v floating on the signal wire which will damage the BOB if it's allowed to flow back into it. By installing the diode, you prevent the 12v from flowing into the bob, at the same time the sensor has 12V+ on the other side of the diode preventing the bob from letting current flow out of pin 13. As soon as the sensor triggers, the signal wire instantly flips to ground allowing current to flow out of pin13 on the BOB causing it to register a switch input.
    Your sensor ground needs to be connected to 12v ground and BOB ground for this to work, but everything in your control box is probably already common ground anyway for power so it should work fine.
