- Limit Switch Help for Controller Box
I purchased a 3 Axis CNC Stepper Control Box, Digital Stepper Motor Driver, 110VAC/220VAC for my G0704 High-Torque Stepper Motor, Stepper Motor, Driver, Stepper Motor kit, DC Servo Motor, DC Servo Motor kit, Stepper Motor Power Supply, CNC Router, Spindle, and other Components. Stepper Motor | Stepper Motor Driver | CNC Router | Laser Machine | 3D Prin. It has what appears to be one D89 male connection on the rear of the box labeled limit switch, and has x, y, z already wired to the KL-DB25 Breakout Board. I would like to add limit switches something like this A60 - INDUCTIVE PROXIMITY SWITCH or A88 - Industrial Limit Switch Will these work with the BOB and existing power supply of the controller box without anything additional added and/or modified? How would I go about wiring 3 limit switches to the one connection? They make setups already wired A61 Inductive Switch Assembly to RJ45 but they have a RJ45 jack that will not work with the controller box as is. Thanks.
- You may not post replies
- You may not edit your posts
Forum Rules
