Hello can the the C10 be equiped with a 300w spindle speed controller to use only with Mach3 if so were do you hook the cables coming from the VFD to the C10 board? appreciate the help Similar Threads: USB BREAKOUT BOARD FOR MACH3Just IN- Mach3, Cnc Breakout Board, CM-126Just IN- CNC Breakout Board, CM-106, Mach3 CNC Breakout Board, CM-106, Mach3New Machine Build- breakout board for mach3
View Tag Cloud
Forum Rules
