Hi everyone i bought the product listed below from automation tech. Running xp 32 bit mach 3 have everything wired correctly to the diagram and i get power to my motors but they do not turn. I check the output ports from my parallel cable and they are working fine. Also the c10 BOB is working fine i see a 5 v in the direction pins on the c10 and up to .02 v on the pull pins. To me this tells me that the board is working. Now how can i tell if my stepper drivers are working something is up seamed to easy to go as smooth as it was going. thanks in advance for any advise and if you need any more info please let me know. Thanks
