Automation Technology Products
Page 1 of 24 123411 ... LastLast
Threads 1 to 20 of 474
Forum: Automation Technology Products
Discuss Automation Technology Products here.
  1. Problem- KL-Series Drivers, Leadshine and Similar Import Drive wiring
    Started by datac‎, 12-13-2017 07:09 PM
    dir, drives, flashcut, sense, source
    12-13-2017, 07:09 PM Go to last post
  2. KL- 8060 Driver problem on new conversion
    Started by rcheli‎, 12-11-2017 09:53 PM
    item#, kl-8060, motor, nema34 steppers, stepper
    12-12-2017, 11:52 PM Go to last post
  3. Solved stepper knocks
    Started by Dean448‎, 12-10-2017 11:52 AM
    g540, kl-6050, kl23h251-24-8b, parallel, series
    12-10-2017, 11:59 AM Go to last post
  4. Gecko G540 vs. KL-4030 drivers (and break out board)
    Started by cncuser1‎, 11-14-2017 10:22 PM
    board, drivers, g540, gecko, kl-4030
    12-06-2017, 08:13 PM Go to last post
  5. Sloppy
    Started by joe90023‎, 11-27-2017 10:35 PM
    11-28-2017, 10:40 AM Go to last post
    10-02-2017, 06:16 PM Go to last post
  6. Question Need Help!- "peak current" or "reference current" configuration
    Started by Djsilva2005‎, 09-27-2017 02:23 PM
    amperage, config, drivers, stepper, temperature
    09-27-2017, 04:43 PM Go to last post
  7. Which Power Supply Do I Need
    Started by Shanghyd‎, 09-23-2017 02:07 PM
    2.8a, 425oz, motors, power, supply
    09-23-2017, 02:07 PM Go to last post
  8. KL 4030 driver problems?
    Started by Kev‎, 08-18-2017 11:47 PM
    2 Pages
    1 2
    08-30-2017, 04:28 PM Go to last post
  9. Proximity sensor wiring
    Started by Lindzr‎, 08-12-2017 11:56 PM
    08-15-2017, 09:29 PM Go to last post
    07-24-2017, 11:53 PM Go to last post
  10. C11GS - Is there an updated wiring schematic?
    Started by Azalin‎, 07-16-2017 11:50 AM
    07-21-2017, 03:52 PM Go to last post
  11. KL-300 Noise & runout
    Started by psykhon‎, 06-10-2017 11:34 AM
    high, kl-300, noise, pitch, runout
    06-10-2017, 11:34 AM Go to last post
  12. Kelling Dip Switch Orientation???
    Started by ny_racer_xxx‎, 03-04-2016 05:28 PM
    2 Pages
    1 2
    0=off, 1=on, kitten, set, switch
    04-24-2017, 03:45 PM Go to last post
  13. Need Help!- Current Settings for KL4042D Stepper Drivers and Stepper Motors
    Started by New Lathe Man‎, 04-01-2017 08:43 PM
    current, mode, set, software, stepper
    04-01-2017, 08:43 PM Go to last post
  14. KL-8070D Software configured mode?
    Started by beltramidave‎, 03-30-2017 11:24 PM
    configured, dip, mode, setting, software
    03-31-2017, 12:21 PM Go to last post
  15. C10 BOB + + USS + 5056D Drivers will not turn motor
    Started by Ambico‎, 06-04-2016 01:59 PM
    03-29-2017, 10:50 AM Go to last post
    03-28-2017, 09:59 PM Go to last post
  16. Solved Sunfar E300 series VFD reset-the spindle runs once again!
    Started by newcreations‎, 03-24-2017 11:33 AM
    deep, plunge, reset, sunfar, vcarve pro
    03-24-2017, 11:33 AM Go to last post
  17. new machine help think my breakout board is fried
    Started by skinny1965‎, 01-27-2017 12:18 PM
    board, check, cnc, set, signal
    01-27-2017, 12:18 PM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 5 users browsing this forum. (0 members & 5 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
