Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 02-07-2010, 05:06 PM
milepost131
Guest
Posts: n/a
DXF file questions
I sent a DXF file to a friend with a CNC (he uses ArtCAM)
I generated the file by taking an Assembly INTO a drawing and then saving as DXF.
The message he got was "Failed to read 3DFACE records from DXF file. Check file contains 3D triangle data"
I haven't got a clue. He hasn't got a clue.
Anybody have a clue as to whether the DXF should contain the correct information and if it does why ArtCAM is puking?
Needless to say the perspective support folks like to point at each other.
Old 02-07-2010, 05:32 PM
jalessi's Avatar
jalessi is on a distinguished road
http://forum.artcam.com/viewtopic.php?f=1&t=393&p=1198
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 02-07-2010, 09:03 PM
ger21's Avatar
Don't use either, but it looks like ArtCAM is looking for 3D faces only, and there are none in your .dxf.
A better option would probably be to export an .stl.
Old 02-08-2010, 11:35 AM
milepost131
Guest
Posts: n/a
dxf and artcam
Interesting.
A DXF file isn't what I thought it was.. or AD decided to make it something else.
I seem to spend as much time "converting" files as generating them!
Thanks.
Gordon
Old 02-08-2010, 06:58 PM
ger21's Avatar
A .dxf file can contain any entity that an AutoCAD .dwg file can, from simple lines to complex 3D solids.
Probably not what you thought it was. AD hasn't changed it, other than adding features with each new AutoCAD release.
Tags
dxf inventor artcam
converting a mastercam 9 file into a Solidworks file Michael82 Solidworks 5 04-17-2009 01:14 PM
Questions On Solid Verify For Multiple Parts That Reside In One File Mastercam User Mastercam 11 12-18-2007 02:02 PM
Bridgeport Series 1 with TNC151 questions about file transfer dbcooper99 Bridgeport and Hardinge Mills 2 09-17-2007 08:38 PM
Questions about NC file tt_raptor_90 Mastercam 2 01-05-2006 08:42 PM
Emc Ini File Questions wholepair LinuxCNC (formerly EMC2) 2 11-17-2005 11:33 PM
