Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 12-16-2009, 12:46 PM
JWWalthall is on a distinguished road
Inventor 2008 units adjustment
How do you set the units precision from 3 decimal places to 4 and it stays that way every time you open Inventor. I can change it in the document properties but it doesn't keep my setting.
Also is there any way to set the size of drill used when you creat a hole feature for a certian size tapped hole. When I creat a 1/2-13 UNC-2B tapped hole it creates a .417 dia hole. This causes a lot of problems when trying to use Feature based drilling in Mastercam as it wants to use a .4219 dia hole wich is the correct size. I can't find anything in help and I have not be able to find any tutorials
Thanks in advance
default units canadamaxxer Solidworks 11 10-07-2010 01:05 PM
Inventor 2008 Modeling a Thread larry53 Autodesk Software (Autocad, Inventor etc) 5 04-06-2009 11:53 PM
dsp handset units xjdubber Excitech routers 0 02-07-2009 09:45 AM
Inventor 2008 larry53 Autodesk Software (Autocad, Inventor etc) 8 11-24-2008 05:35 PM
Setups Units boyvox Mach Software (ArtSoft software) 2 10-17-2006 09:47 AM
