Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 12-08-2009, 10:23 AM
80083r is on a distinguished road
Change starting revision of sheet?
I'm using Inventor 2010.
Is there a way to change the default revision that a sheet has?
It starts at <blank> but I'd like it to be "-". I've tried changing the revision of the sheet in the template, but that doesn't carry over.
I can edit the sheet properties on each new drawing, but I'd prefer it to start at what I want - my boss doesn't like clicking on the sheet, editing and typing in a "-".
Old 12-08-2009, 09:24 PM
MarkWink is on a distinguished road
I was able to change the Revision Number with a "-" in the templates directory of the standard.idw and have it be there when opening a new standard.idw.
So it is possible, maybe your template file is set to read only?
Old 12-09-2009, 07:15 AM
Nope - I can make other changes to the template. I'm using .dwg, not sure if that makes a difference.
Are you changing the revision of the whole thing, or just the sheet? I'm changing just the sheet - we have many multi sheet drawings, and we revise individual sheets.
Old 12-09-2009, 11:10 AM
I did it with just one sheet initially, when placing a new sheet in the drawing it displays the "-" in the Title Block as Rev.
I'm doing this with .idw file type and from new files not existing.
G320X First Revision Manual CoAMarcus Gecko Drives 0 08-05-2009 06:35 PM
Revision 2 of FLA100-00, a full 2'x3' router table plan. solodex2151 DIY-CNC Router Table Machines 5 02-27-2009 11:40 AM
New revision PCB's and coolant operation iGG1e Syil Products 4 03-17-2008 10:43 AM
MC9 POST for MACH3 - Updated Revision chris59 Screen Layouts, Post Processors & Misc 5 10-13-2006 06:55 AM
How to change the setup sheet format? cwww General CAM Discussion 2 06-30-2004 02:28 PM
