Results 1 to 2 of 2
Thread: Autocad LT 2008 Total inches in drawing?
    Jun 2008
    I have searched for a method of getting the total measurement of lines in my drawings and found LISP to be the simplest method but also that my LT version does not support LISP. I am trying to find a way to get the total length of the lines in a draft so that I can calculate times based on an IPM (Inches Per Minute) multiplied by the total length of all lines within the drawing.
    I would appreciate ANY help you guys can offer. Thanks in advance.
    Gawker
    ETA - I'm drafting for ESAB machines and using Columbus for the machines just in case anyone here is similarly equipped and knows of a way to access the same information from THAT software rather than AutoCAD itself. Thanks again.
    Mar 2003
    Shelby Twp, MI....USA
  1. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 05:34 PM
  2. Need Help!- With AutoCad Drawing.
    By Stampede in forum BobCad-Cam
    Last Post: 02-18-2009, 01:45 AM
  3. Need Help!- How too, AutoCad drawing to BMP/JPEG
    By Holmes_ca in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 02-17-2009, 10:05 AM
  4. join lines, Autocad 2008
    By vividdezigns in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 10-27-2008, 06:00 PM
  5. autocad 2d/3d drawing/render into partmaster?
    By BulleTxMagneT in forum Dolphin CADCAM
    Last Post: 01-28-2008, 09:39 AM
