| Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here. |
i have posted a thread in the mastercam section thinking that the problem was occuring when importing a file to mastercam (x3) but after reopenning the same file (ipt or step) in inventor the curve do not appear as cuve but as a serie of small line, the problem is that mastercam then base its toolpath on those small line and not a curve so i am not getting hole but a polygon
__________________ The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne |
| -step -ipt -iges part are mostly 3d, i have figured how to get the file to be displayed properly in inventor but not in mastercam nomather if they are step, ipt, iges..? i also have a thread started in the mastercam section about this problem to see if its not mastercam who as a problem mastercam thread
| That's only for visualization purposes. The circle it's still a circle. I'll post the solution (settings) so you can see the circle as a circle later, I just want to let you know guys that is just a viewing setting, that's it. Cad software is all about polygons viewing. The more polygons you have the more overloaded the software will be if you are working with millions of elements. That's why the option of fewer polygons (for viewing purposes) is better when you work with huge amount of data. Chillax... |
| POLYGON TURNING | Stebedeff | G-Code Programing | 1 | 09-25-2008 08:31 AM |
| Determining "speed hole" spacing and size? (weight saving cutouts) | douglasco | Mechanical Calculations/Engineering Design | 8 | 08-04-2008 03:26 PM |
| Polygon Grinding | gsmadhuchandar | General Metal Working Machines | 0 | 07-20-2008 03:41 AM |
| Which is better Polygon or Arcs? | Normsthename | Mach Plasma / Laser | 9 | 02-03-2008 03:45 PM |
| turn polygon help | CNCRim | Fanuc | 1 | 09-07-2006 07:18 PM |
