Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 08-05-2009, 12:24 AM
m98custom1212 is on a distinguished road
Inventor 2010
I was wondering is there cut feature in inventor something like in solidworks
Im learning inventor. I cant find anything i learned solidworks at school
make a section view on the part
THanks
Old 08-05-2009, 08:53 AM
James L is on a distinguished road
Section Views
By cut, are you meaning section views? If so, then yes Inventor can do it. You need to be in drawing mode to do it. Create a new .dwg and put your part in it.
The controls in 2010 are a bit different from 2009 which is what I am used to but there is a very wide range of things you can do in dwg.
Old 08-05-2009, 04:52 PM
i talking about in the part model not in the drawing
and cut i mean like slots and etc
Old 08-05-2009, 08:08 PM
diycnc is on a distinguished road
isn't it in the extrude function? don't recall as i only used it for a bit
Old 08-06-2009, 09:15 AM
Extrude
Yes there is an option in extrude where you can cut. Just start a new sketch on the surface where you want the cut and create the geometry of cut. There are 3 choices in the extrude options and 1 on them will be cut.
Old 08-06-2009, 11:00 PM
ty james that is what i was looking for
can u revolve cut?
Old 08-10-2009, 10:01 AM
Revolve
As far as revolving using the extrude feature, I am unsure how to do this.
I know geometry can be revolved but I have never tried to cut doing this. If i needed a curved 'cut' in the part I would make the geometry in my sketch curved to the shape. Sorry I can't be more helpful here.
Old 08-10-2009, 10:16 AM
JoeyInCali is on a distinguished road
You can also import i-features from the content center.
One of them is slots. You modify that feature as well.
Easiest way to revolve a cut is to draw that part with the cut, then revolve that drawing. When you revolve you can set the diameter.
Old 08-10-2009, 01:34 PM
that is way i usually do it but i seeing if inventor was had that feature or not
Old 08-12-2009, 10:58 AM
gillyhyde8888 is on a distinguished road
Cut command
You cut by first creating a sketch on a face or a work plane. The use the extrude command and select cut.
You can also cut with most other commands such as sweep loft rerlove etc.
Hope this helps
Ive been using Inventor from R3 and have all the wounds to prove it. Were supposed to be moving over to Solidworks.
regards
Christian
  #11   Ban this user!
Old 08-12-2009, 09:22 PM
Hope this helps
regards
Christian
Why not Inventor 2010 if I may ask?
  #12   Ban this user!
Old 09-10-2009, 05:21 PM
Thumbs down Still using 2010
I still try to use 2010, but its crap, they just don't fully test things!! its slower than ever, and it messes other stuff up when you try to run them together, which you do when your designing. It wont run proberly with Autocad 2010 and adobe to name a few.
I cant wait for the company to go bust, which I'm sure it will.
The only solid programe they ever produced was Autocad 14, which was very reliable and stable, quicker to produce design detail and assembly drawings 12-15 years ago, than now, will this over complicated unreliable sh*te.
Oh, the manuals and tutorials are also bollocks, typical american mumbo jumbo salesmans patter (not ment to affend any yanks, but we did win the war, although ...... well thats another story)
Regards
Christian
Got Inventor 2010 today. single phase Hypermill 16 06-20-2010 10:19 PM
2008 to 2010 camtd Solidworks 1 03-02-2009 08:05 AM
2010 drives not running normally. Splint Servo Drives 12 07-06-2008 09:56 PM
2010 Tool Not Available - Fanuc Om PPM Fanuc 3 08-24-2005 03:22 PM
2010 power requirements? Splint Servo Drives 1 06-26-2005 08:21 AM
