Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: autocad to pdf
    Jan 2005
    autocad to pdf
    Hi everyone
    Can someone tell me how to get a dwg into a pdf document so it will print to scale? I can get it in, but it prints smaller and I want to use them as templates. I am making some plans to email and since everyone dosen't have autocad. I need to have them in pdf format. Thanks
    Registered wjbzone's Avatar
    Apr 2003
    andy,
    The best way I know is to use Adobe Acrobat Distiller.
    http://www.cdw.com/shop/products/def...spx?edc=663936
    You just select it like any other printer and the plot goes to an adobe file.
    Bill.
    www.joescnc.com joecnc2006's Avatar
    Aug 2004
    Try this one, i have used it up to size "D" sheets and works well, You have to print out of autocad at a 1:1 and print on a plotter if you have large sheets. Or put a scale on the drawing so they know how much to inlarge it.
    Also its free.
    http://www.primopdf.com/
    Jan 2005
    Thanks guys.
    I have been using primo. But I can't get it to print to scale. I may be doing somthing wrong. The templates are small and will fit on regular paper.
    Jan 2005
    OK i got it.
    I was using autocad LT. I had to use the full version to get the plot right.
    Thanks for the help.
    Andy
    *Registered User*
    Sep 2004
    Don't forget that Autocad now has DWF format. It is MUCH more efficient in file size than PDFs, and has other benefits as well.
    Anyone can download the DWF Viewer for free from Autodesk's website.
    Chris
    Jan 2005
    I was not aware of that Thanks Chris
    Andy
    Jan 2005
    Guys
    I got what I ask for but, that’s not what I really needed.
    I did not realize I could not edit a pdf file. As it is now I have to
    create each template as a separate file. So I end up with several separate files to send.
    What I need is to get autocad drawings into a word document
    and keep them to scale. Then convert to pdf. still keeping them to scale and send as one file.
    Any ideas?
    Thanks Andy
    *Registered User*
    Sep 2004
    Not sure I understand why you need to do what you explained. If you are looking to put all the drawings into one PDF file, try downloading a PDF print driver like PDFfactory or PDFfactoryPro from fineprint.com.
    Instead of printing from Autocad to the printer, you select this print driver which sends the data to a separate utility where you can accummulate multiple PDFs into one file.
    They have a free trial period. Assuming you pick the right scale for the right size paper, you should be able to print to scale.
    In AutoCAD 2005 you are able to put multiple DWF files into one file, similiar to my description above for PDFs.
    Chris
    Jan 2005
    Yes Chris
    Thats excatly what I need to do. Combine multipal pdf files into one. Sounds so simple when you put it that way. Duh!
    I will try PDFfactory.
    Thanks again Andy
    Jan 2005
    I got pdfFactory pro. It's just what I needed.
    Thanks again Chris.
    Andy
    *Registered User*
    Sep 2004
    Glad I could help.
    Chris
  • Page 1 of 2 12 LastLast
    1. AutoCAD offsets and copying
      By skippy in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 05-19-2005, 02:12 PM
    2. Autocad user has newbie SW/CNC questions
      By cadesignr in forum Solidworks
      Last Post: 02-11-2005, 02:19 PM
    3. AutoCad 2000 DXF Question
      By Holmes_ca in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 01-19-2005, 06:50 PM
    4. Edgecam with Autocad dwg for Lathe
      By wjbzone in forum General CAM Discussion
      Last Post: 01-05-2005, 12:54 PM
    5. AutoCad 2000 Missing .dll file
      By E-Stop in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 05-30-2003, 12:43 PM
