Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 02-13-2005, 03:55 PM
rfstar is on a distinguished road
calculator in Autocad
Is there anyway to have a calculator feature in autocad 2002, Im looking for something like Mastercam or cadkey, where you can enter calculator funcation in the different fields
Thank In Advance
Old 02-13-2005, 04:43 PM
Gold Member
JFettig is on a distinguished road
just type 'calc' and hit enter.
then you just enter stuff in, its pretty basic.
Jon
Old 02-13-2005, 05:02 PM
nope sorry "calc' didn't work is there a lisp I need to load first?
Old 02-13-2005, 05:05 PM
Gold Member
sorry, i just rememberd its 'cal', I just tried it and works
Old 02-13-2005, 05:11 PM
Cool!!!!!! you know how long i have been looking for that feature, one last thing though is there anyway input the final valve ? for things like offset and such ?
Thanks again
randy
Old 02-13-2005, 05:13 PM
ger21's Avatar
You can also type lisp expressions during some commands. Say you're using the array command, and want 4 objects in 11 inches, for the offset just enter (/ 11 3.0), which is 11 divided by 3 (3 spaces between 4 objects). One of the numbers has to have a decimal or it will get rounded off.
Other examples:
(+ 1 2) = 1+2
(* 3 4.0) = 3/4
(- 6 5) = 6-5
Old 02-13-2005, 05:14 PM
ger21's Avatar
The above examples work for offset, I use it all the time when I need a metric dimension and I'm drawing in inches. 45mm in inches = (/ 45 25.4)
Old 02-13-2005, 05:18 PM
Wow !!!!!!!!! thats great Gerry Thanks Alot, this will be a BIG help
Old 02-13-2005, 06:09 PM
ger21's Avatar
You can also nest them, if you need something more complicated
(/ (* 12 4.5) (* 4.3 6))
(12 * 4.5) divided by (4.3*6)
Old 02-14-2005, 06:13 PM
greggv is on a distinguished road
So, how do you get that calculator function in Mastercam? It would be kinda helpful sometimes when you can't reach the calculator. The tip for Autocad is cool! Thanks for that one!
  #11   Ban this user!
Old 02-14-2005, 06:16 PM
greggv:
Thats Easy in Mastercam ALL fields you just simply type 2+2 then enter and it will enter 4 for you !!
  #12   Ban this user!
Old 04-12-2005, 01:04 PM
JoelDirn is on a distinguished road
Thanks again
randy
add a single quote in front of the command to use cal with another command.
Like this:
Command:Offset
Specify offset distance or [Through] <1.0000>: 'cal >> Expression:
AutoCAD offsets and copying skippy Autodesk Software (Autocad, Inventor etc) 14 05-19-2005 01:12 PM
AutoCad 2000 DXF Question Holmes_ca Autodesk Software (Autocad, Inventor etc) 8 01-19-2005 05:50 PM
Edgecam with Autocad dwg for Lathe wjbzone General CAM Discussion 4 01-05-2005 11:54 AM
Autocad LT verse AutoCad LT CNCadmin Autodesk Software (Autocad, Inventor etc) 2 02-03-2004 07:28 AM
AutoCad 2000 Missing .dll file E-Stop Autodesk Software (Autocad, Inventor etc) 12 05-30-2003 11:43 AM
