Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 06-16-2009, 03:51 AM
riverracer is on a distinguished road
plane setup
acad lt 2005
is it possible to set a dwg/template up so that i can draw in 2d on the Z-X axis instead of on the Y-X ?
if so how?
reason is so that i can then export to a cam program in the correct plane without having to rotate it.
thanks
Old 06-16-2009, 08:12 AM
ger21's Avatar
Never used LT, but in AutoCAD, you can use a right side view to draw. The UCS may still show X and Y, but it'll export as Y and Z.
r plane commands ghostlx G-Code Programing 2 06-04-2008 01:03 PM
construction plane and tool plane nervis1 Mastercam 9 11-04-2004 11:53 PM
Arc In Z And X Plane ljoe1969 G-Code Programing 10 04-27-2004 09:32 PM
My New plane CNCadmin CNCzone Club House 17 11-25-2003 11:25 AM
cycles initial plane/retract plane HuFlungDung OneCNC 25 06-26-2003 07:02 PM
