Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 06-10-2009, 03:24 PM
Cmzwirner is on a distinguished road
SLDPRT to .dwg conversion!
Does anyone have any knowledge on how to convert a SLDPRT file to a .dwg file?
If anyone can do it, it would be great if you did it for me, or explained how to do it to me.
Thanks!
Old 06-10-2009, 06:01 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
File\Save As...
Select .dwg format.
Paul
Old 06-10-2009, 06:52 PM
Originally Posted by fatal-exception View Post
File\Save As...
Select .dwg format.
Paul
All i have is solidworks, and it doesnt have .dwg as a save option.
Old 06-11-2009, 07:29 AM
ghyman's Avatar
ghyman is on a distinguished road
Use SW to create 2-d drawings, then "save as" to save into dwg format.
Old 06-11-2009, 07:48 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
DITTO
www.integratedmechanical.ca
Old 06-11-2009, 09:53 AM
Sorry, that's to save a drawing in autocad format.
The only save option I see in solidworks is ACIS format, but when I tried to open a part in autocad, it gave me some type of error.
Why downgrade your model to autocad anyways?
Paul
Old 06-11-2009, 10:19 AM
ger21's Avatar
Try an older version of ACIS out, and in AutoCAD, use Insert > SAT.
Old 06-11-2009, 10:21 AM
ghyman's Avatar
Well whaddya know... I never knew acad could import acis files!
save the solid to SAT format, set "Output As" to "Solid/Surface Geometry", and i used the oldest version available (just to be sure)
"acisin" from the command line in acad, and there it is!
cool.
Problem- BobCAD V23 won't open Solidworks 2009 sldprt MBX5 BobCad-Cam 2 06-01-2009 01:23 PM
Need Help!- Import solidwork .sldprt file bowersjack BobCad-Cam 5 10-27-2008 06:50 AM
convert sldprt Greg Maxwell Autodesk Software (Autocad, Inventor etc) 3 07-31-2008 12:52 PM
servo conversion vs stepper conversion contractdesign Bridgeport and Hardinge Mills 3 07-26-2008 02:54 PM
Solidworks SLDPRT to Bobcad toolmap? Green0 BobCad-Cam 2 01-14-2007 07:47 AM
