Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 05-14-2009, 10:31 AM
SPEEDRE is on a distinguished road
Operation of Inventor?
I have a Certificate in Auto CAD 2000, 2d, and an A.S. Degree, Mech. Eng. with SolidWorks 2008.
How much different than SolidWorks is it. I've been told, once you learn 3d operations, it can be easy to work any other type software. Extrude is extrude is extrude, if you catch my drift.
Old 05-14-2009, 10:44 AM
somes31 is on a distinguished road
I was taught Autodesk Inventor in school and now I am using SolidWorks where I work, basically the same program, really easy to make the switch
Old 05-14-2009, 06:36 PM
ger21's Avatar
I've played with Inventor, Alibre, Solidworks, and one other that I can't recall that had a free version a few years ago. They all work basically the same way.
Old 05-15-2009, 11:45 AM
NEATman is on a distinguished road
I use inventor at work and Solidworks at home. If you know solidworks well and you use proper modeling techniques, you should be albe to learn it in very little time.
I have noticed that using the fillet command is much more challenging on complex parts in Inventor, but aside from that, they are about equal.
NEATman
Old 05-17-2009, 11:09 AM
Thanks guys. I thought as much. I often see it on employment requirements and wondered if I could migrate to it.
Old 05-20-2009, 09:32 AM
Johan Cnczone's Avatar
Johan Cnczone is on a distinguished road
I used to work with solidwork, switched to inventor 2 years ago
Basically it is as easy as solidwork, but maybe the workflow is a bit different ( you start a design in assembly environment, not in part environment )
Inventor LT single phase Hypermill 2 08-03-2007 02:42 PM
Inventor to Cam/G VSNT Autodesk Software (Autocad, Inventor etc) 4 07-31-2007 05:39 PM
Mastercam X Inventor 10 ozzie34231 Mastercam 5 03-14-2007 06:08 AM
Inventor 11 single phase Hypermill 10 06-27-2006 11:07 PM
Inventor 8 cnc wizard Autodesk Software (Autocad, Inventor etc) 4 11-18-2004 02:38 PM
