Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 03-25-2009, 04:52 AM
CNC-Hammer is on a distinguished road
Modelling & linetypes
Hi guys,
further to me recent post(s) I would like to know about linetypes when modelling. I have done very little modelling and understand that a 2D drawing can be created from the 3D model. I just wondered what needs to be done to show different linetypes in the 2D drawing such as a hidden profile when taken from the 3D model.
I have only ever done a 2D drawing or a separate 3D model and not one from the other.
Thanks!
Old 03-25-2009, 05:58 AM
ger21's Avatar
Is this AutoCAD?
Old 03-26-2009, 01:43 AM
Sorry, yes it is Acad 2008!
I have done some further research using some old R14 books I have and they mention using PROFILE command. Is this still the case? If so I'll give it a go soon.
Old 03-26-2009, 06:59 AM
ger21's Avatar
Look in the help file for SOLVIEW and SOLDRAW commands. I believe that they will automatically do the hidden lines. I've only played around with these once or twice, though, as I prefer to draw the 2D myself.
Old 03-26-2009, 05:18 PM
Thanks Gerry,
I believe those are the commands that I read about.
One other thing, can you advise the best way to draw a threaded hole on a 3D model so the 2D drawing shows the core diameter as well as the thread diameter?
Old 03-26-2009, 05:23 PM
ger21's Avatar
I'd just add it to the 2D drawing.
Old 03-27-2009, 01:31 AM
Exactly what I was thinking!
Old 03-27-2009, 11:27 PM
wages is on a distinguished road
been a while since i've done this, but i think SOLPROF and FLATSHOT will help, don't forget SECTION also
FLATSHOT creates a flattened view of all the 3D solids and regions in the current view. The resulting view is a block that is a flattened representation of the 3D model
Old 03-28-2009, 12:00 AM
ger21's Avatar
I'd never heard of Flatshot, but it's pretty sweet.
Old 03-30-2009, 07:32 AM
Ok guys I'll give that a go when I get a chance.
What is the correct 3D convention when modeling internal or external threads in AutoCAD?
For an internal I would guess the core diameter. For external obviously the OD but how would the core or thread length be represented on the model?
  #11   Ban this user!
Old 03-30-2009, 09:58 AM
Typically the hole is modeled at the ID for parametric modelers that have a hole tool. See attached video for how this is done in Inventor.
Also, note that AutoCAD Mechanical has a hole tool as well, Here's a quick video showing it also.
Hope this helps.
  #12   Ban this user!
Old 03-30-2009, 10:14 AM
jrlifter's Avatar
jrlifter is on a distinguished road
if you can email me an iges or parasolid of your drawing I can send you back a 3 view ortho you can work with for your toolpaths..
jrlifter1971@hotmail.com
PRS modelling betterfly Musical Instrument Design & Construction 7 08-13-2008 04:00 PM
3D modelling in the real world ksealey WoodWorking 2 11-30-2007 01:06 AM
Modelling a Guitar for a Variax transplant nshack31 Autodesk Software (Autocad, Inventor etc) 1 03-16-2006 09:24 PM
Learning 3D modelling randyf1965 Alibre Design 2 01-12-2006 06:27 AM
guitar neck modelling.... anoel Rhino 3D 9 04-16-2004 11:33 PM
