Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 03-11-2009, 02:32 PM
SPEEDRE is on a distinguished road
How to change ugly font
I really think the default text. It is an ugly tecno font style. I'd like to cahange it to a new style defalt. How do I do that????? Anybody have an ideas as to.
Old 03-11-2009, 02:36 PM
ger21's Avatar
Format>Font Style
Old 03-11-2009, 02:37 PM
ger21's Avatar
Actually, it may be Format>Text Style.
Old 03-12-2009, 04:34 PM
I actually do that already. Is there a way to permanently reset it without changing it with format every time I make a new drawing ? Know what I mean Ger21. I'd like to start out with the font of my choice instead of some ugly techno stick font.
Old 03-12-2009, 04:55 PM
ger21's Avatar
Set up everything you want, then save it as a template. Then start every drawing with that template.
I use two templates, one for actual drawings, and one for machining .dxf files. The templates can have your layers set up, lineweights, dimension styles. Just about anything.
Spend 30 minutes setting up everything exactly how you want it and you'll never have to do it again. I've been using the same templates for close to 8 years, maybe more. Through several versions of AutoCAD.
Old 03-13-2009, 12:13 PM
Thank you ger21. I must truly be brain dead. I knew that doh!!
Old 03-14-2009, 11:13 PM
CNC-Hammer is on a distinguished road
Exactly what I needed
I was having the same problem of setting a font then losing it everytime I started a new drawing.
I just couldn't remember how to fix it.
Many thanks!
font options? fokusco Haas Mills 7 04-16-2009 12:35 PM
Just IN- Large font small font CNCadmin CNCzone Site News and Contests 0 10-26-2008 12:47 AM
GD&T: The Good, The Bad, And The Ugly Side..? cncprofessor Polls 0 01-09-2008 10:45 PM
Font ejdfast BobCad-Cam 3 12-14-2006 02:07 PM
Ugly Stick PaulH Hobby Discussion 13 10-05-2005 04:00 PM
