Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 12-09-2008, 08:54 AM
Babba is on a distinguished road
Beginner Needs Help
I'm CNC milling a profile to match an existing products base ( a riser block) but I'm having some difficulty.
I've traced & scaled the original profile as best I can but when this is translated into CNC code there are lots of imperfections in what should be a smooth flowing although complex curve.
Is there an easy way of smoothing out the curves on this profile other than experimenting with the exact position of each node???
I'm totally self taught on Autocad so forgive me if even the basics aren't quite right.
Old 12-09-2008, 07:43 PM
ger21's Avatar
Imo, you have far too many points in the spline. I don't think there's any way to smooth it out other than node by node, but even that would be very difficult to do.
Any chance of a pic of what you traced?
Old 12-11-2008, 11:36 AM
bunnifer451 is on a distinguished road
How are you exporting the data from ACAD and what CNC software are you using?
Old 12-11-2008, 11:52 AM
GAONKAR is on a distinguished road
Try with Fagor DNC software Your autocad.dxf file will generate the CNC program.
Old 12-11-2008, 10:41 PM
Fagor - Todd is on a distinguished road
You may want to applying a G05 (corner rounding) in the beginning of the program. This is a modal command and is cancelled by G07 (Square corner)
There is a general machine parameter that asks which one is default at start-up..... this will tell you which one has been active.
good luck !
Beginner cnc574 CNCzone Club House 7 01-03-2008 07:07 AM
Beginner bobby1 BobCad-Cam 3 03-17-2007 03:50 PM
Beginner NetStorm BobCad-Cam 3 02-13-2007 07:38 PM
Beginner needs help David Da Costa Mini Lathe 5 06-27-2006 12:18 PM
another beginner, maybe! shootingarts General Metal Working Machines 13 08-11-2005 08:42 AM
