Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 12-08-2008, 09:27 AM
skippy is on a distinguished road
AutoCAD shape solid fill
I want to get some 120mm x 42mm x 0.8mm (5" x 1.75") aluminium nameplates made (one-colour screeenprinted) and unfortunately I don't have nor do I know how to use a vectorial design program (Illustrator, etc) other than AutoCAD. I've done the artwork in DWG format and I need to do one of the two following things. (a) Export the artwork to a format that the nameplate people can use or (b) send them the dwg/dxf files, they print them out and reproduce them via photographic means.
(1) Can AutoCAD export to some sort of format they will be able to use? Is WMF a widely used format? EPS would be nice but I don't think AutoCAD will export in that.
(2) If I go for the second option, I need to solid fill the border line and the silhouette of the kanguroo so that it will print correctly. How do I do that? (or would someone be so kind and fill it for me?)
thanks for your help
Phil
Old 12-08-2008, 01:30 PM
anybody????
Old 12-08-2008, 01:31 PM
jpgdesigns is on a distinguished road
Go to File-Export and see the Files of type: WMF & EPS should be listed
you can Hatch using a solid fill or hatch with a pattern at a very small scale to look filled
Old 12-08-2008, 05:00 PM
thanks jpgdesigns
Phil
SMTC Oil Fill? big_mak Haas Mills 8 03-21-2011 06:54 PM
Need Help!- Pocket / fill kghinsr BobCad-Cam 10 06-02-2008 08:47 AM
Hole fill? pp-TG Mastercam 6 03-15-2007 03:59 AM
Can,t fill my object ZipSnipe TurboCAD/CAM 5 02-27-2006 08:07 PM
dxf to G-code...how to fill? UCFMems Autodesk Software (Autocad, Inventor etc) 6 06-25-2004 11:26 AM
