Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 11-23-2008, 04:19 PM
slammedxonair is on a distinguished road
Illustrator to Autocad Help
Hello everybody I have been trying to convert a customers adobe illustrator .eps files over to Autocad for a couple days now so I can cut them on my Plasma table. I have tryed a ton of different things and searched all over with no answers. I just need to get this going asap.
I go into Illustrator and export as a dxf and even dwg it converts the lines fine but, when I open it in Autocad 2006 the drawing is no where close to scale and way to big. So every time I try to scale it down in Autocad or even take a diminsion off of it to see where I'm at Autocad just freezes up and will not do anything.
Does anybody know what I need to do preferably export at normal size if possable. Thanks for any help I just really need to get this project going.
Old 11-23-2008, 04:28 PM
ger21's Avatar
Can you post a sample I can try in AutoCAD?
I've used this in the past to convert eps to .dxf for AutoCAD.
http://www.pstoedit.net/
Old 11-23-2008, 04:30 PM
bcwan is on a distinguished road
try to export it from Illustrator as wmf file and then import it to Autocad with WMFIN command
Old 11-23-2008, 04:50 PM
it opened but it only has 1 point where it was inserted, it wont let me check dimensions or anything.
Old 11-23-2008, 04:57 PM
i downloaded that and installed it but theres no program or anything. i have no idea how that works lol.
Old 11-23-2008, 05:56 PM
ger21's Avatar
Oops. While pstoedit is what gives you the .dxf, you actually need Ghostscript. Ghostscript actually uses pstoedit. You might want to also download GSView, which is a front end for Ghostscript, which if I recall is a command line program. It's a bit tricky to set up, but works well once set up.
http://www.ghostscript.com/awki/Ghostscript_Website
http://pages.cs.wisc.edu/~ghost/gsview/index.htm
Old 11-24-2008, 01:24 AM
Well after hours of working on this I finally found this!
http://www.baby-universe.co.jp/en/pl...cts/exdxf-pro/
You can use the trial 30 times and then its like $90 to buy it. It worked great! so if I keep having stuff like this come up I'll probably end up buying it.
Thanks everybody and this may be some good information for anybody who needs it in the future.
Old 11-24-2008, 03:18 AM
perhabs i don't understand what you exactly mean but
exporting from Illustrator to WMF (not DWG or DXF) is to have an the drawing outline and not filled with hatchs witch you cant explode in AutoCAD.
and
when in ACAD use the wmfin command and that will let you to specify the insertion point and a scale for the x axis and y axis and a rotation angle too.
you can specify the insertion point and then accept the scales as 1 by using just enter, enter and then you can explode the block and you can scale it as you need after.
hope this will help, good luck
Adobe indesign and illustrator dpmulvan General CNC (Mill and Lathe) Control Software (NC) 0 11-18-2007 01:31 PM
Generating paths (Gcode) from Illustrator CS2 bigal General CAM Discussion 1 06-14-2007 04:05 PM
illustrator sunlight Autodesk Software (Autocad, Inventor etc) 11 03-11-2007 01:40 PM
Adobe Illustrator to CNC software?? HELP merlin1974 General CAM Discussion 11 07-23-2005 03:06 PM
Adobe Illustrator Files JOE65 Autodesk Software (Autocad, Inventor etc) 2 02-09-2004 04:20 PM
