Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 10-08-2008, 08:43 AM
todd_fink is on a distinguished road
Microscribe MUS returning only 8 characters to AutoCad
We are using a Microscribe G2 digitizer and AutoCad 2004 to create 2D shapes. We are using Microscribe's MUS software to send the point data to AutoCad. Recently, the MUS utility is returning only 8 character strings for the point representation. This defines the actual points incompletely because there is actual more than 8 characters of data. If we set the x,y values to return 4 decimal places in MUS, the x value will be returned and the y value will only be partially returned. Let's say that the Microscribe is pointing to (1.5,2.5). If the MUS format string was set at "%.4f,%.4f/n", the values returned would be "1.5000,2". If the format string was set to "%.2f,%.2f/n", the values returned would be "1.50,2.5". Now, let's say the Microscribe is pointing to (10.5,20.5). If the format string was set at "%.4f,%.4f/n", the values returned would be "10.5000,". If the format string was set to "%.2f,%.2f/n", the values returned would be "10.50,20".
You will note that these values are problematic as they don't define the actual location of the stylus to the AutoCad command. How can I get the MUS utility to return more than 8 characters to the AutoCad program?
Returning a new machine. SIG General Metal Working Machines 2 02-20-2008 01:27 PM
Bad Characters gplush Haas Mills 5 02-08-2008 11:00 PM
Reset mach 3 after stoping pogram and returning home Prboz Mach Mill 0 12-12-2007 05:05 AM
Returning to 0,0,0 planekrazie Mach Mill 7 07-19-2007 05:28 PM
Connecting to Microscribe 3dx robinsoncr Digitizing and Laser Digitizing 4 03-03-2007 01:26 PM
