| Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here. |
I've spent way to long trying to figure this out.... I have a complex shape. I want to make a mold cavity out of it. But if I extrude a box around it, I can't cut it so that the complex shape is removed. The cut Boolean is very restrictive. Basically - I can't figure out how to make a mold cavity in Inventor. Any suggestions? I'm sure this will be easy once someone lets me in on the secret.
__________________ bgraham111 www.lightningrobotics.com and www.sallysgeckoranch.com |
| I can't comment on Inventor, but Cadkey 19 has a boolean difference function that subtracts one solid from another. You'll probably have to use a two or four part 'block' to enclose your shape. Perform a boolean difference on each of the sections. The Cadkey function works 99.9% of the time; some shapes generate an error. No idea why.
__________________ Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers |
| Create a "Derived" component from your model. I do this all the time to create core boxes for moulding. Basicly does a subtract from your positive model leaving the cavity in a box. Should be examples under the help files. Look up derived component. Cam |
| In some cases, the molded part can't be molded and ejected from a 2 part mold. I'm not a big mold guy, but I have seen molds with what they call "slides" for complex mold cavities such as you've mentioned. Hope that helps, sorry I can't be too much more specific, you almost need to talk to an engineer in the mold industry. |
| mc-motorsports: No need for a slide or horn pins. I'm just doing this at home for some poured soap molds. The think that was frustrating me was that I design complex, multi-slide tools at work, for class-A surfaces. I just couldn't do a simple single pull tool at home, only because I use inventor at home. I just tried it and it worked like a charm. Just hard to find in the menus if you don't know where to look. THANKS EVERYONE!!!!!!!!!!!!!!!!!!!!!!!
__________________ bgraham111 www.lightningrobotics.com and www.sallysgeckoranch.com Last edited by bgraham111; 09-26-2008 at 08:11 AM. |
| Hey all I been really struggling with getting this derived component to work. I have drawn my core and is saved as .ipt I have drawn a block as my mould and also saved as .ipt. Deriving component just seems to overlay it with no option of subtracting core shape from block. i tried playing with .iam but just frustrating myself and am meant to have this cutting yesterday. Someone please tell me the proper process. Thanking you in advance. |
| Autodesk Inventor Mold (beta) | EL DUKE | Autodesk Software (Autocad, Inventor etc) | 3 | 05-12-2010 06:57 PM |
| Making Mold and Die | BrassBuilder | Dolphin CADCAM | 20 | 04-22-2008 11:49 AM |
| Making a positive mold from a negative mold - how? | SRT Mike | Moldmaking | 7 | 03-29-2007 04:30 PM |
| Mold making with Deskcam | Jon D | Carken Products (Deskam, DeskCNC etc) | 2 | 02-08-2007 03:41 PM |
| Welcome to the mold making forum. | CNCadmin | Moldmaking | 0 | 07-07-2003 11:22 AM |
