Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 05-19-2003, 12:38 PM
JOE65's Avatar
JOE65 is on a distinguished road
Line weight
Hey Guys
I'm using Acad 2000 and would like to get a line weight of .25" to similate cutter diamiter in my drawings.
The largest weight available seems to be 2.11mm.
So the question is how do I get 1/4" line weight?
Old 05-19-2003, 12:42 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Can you just offset the lines and fill it in with a solid hatch?
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 05-19-2003, 05:42 PM
ger21's Avatar
The help file specifically says not to use lineweight to represent an actual width, which is probably why they won't let you do it. If you want to see the offset while you're drawing, use the offset command. If you want it for plotted output, you can get any lineweight you want by using plot styles.
Old 05-20-2003, 10:47 AM
wjbzone's Avatar
wjbzone is on a distinguished road
Use a polyline (two arcs). You can set the width using pe (polyline edit)
Old 05-20-2003, 11:31 PM
JOE65's Avatar
Thanks for all your help guys
Poly line width has it!
Now I can draw my parts and use pedit width to make sure my tool paths are doing what there told
single line fonts? balsaman General CAM Discussion 12 02-18-2006 11:51 AM
Single Line Fonts A. Shuford General CAM Discussion 1 11-14-2004 08:21 AM
Z-AXIZ weight signIT DIY-CNC Router Table Machines 8 07-01-2004 04:35 PM
Possible gantry weight problems samualt DIY-CNC Router Table Machines 9 12-03-2003 12:29 PM
Tool tables Nimrod Mastercam 4 11-24-2003 02:31 PM
