Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 08-22-2008, 04:06 PM
Reg wharton's Avatar
Reg wharton is on a distinguished road
Autocad 2000(changing point size)
I recently installed autocad 2000 on windows vista and I can't access the help files. Does anyone know how to change the size of points.(I want to make them bigger).
thanks.
Old 08-22-2008, 07:10 PM
ger21's Avatar
Try ddptype.
Old 08-23-2008, 03:24 AM
bcwan is on a distinguished road
Yes, ddptype do the job
or
under the format menu you'll find point style
and there you can set the points size relative to screen or absolute
I guess points bigger to be able to select a point and for that you have to check the NODE Snap to object mode.
hope this help
Old 08-23-2008, 02:54 PM
autocad 2000
thanks everyone that did the trick. How can I make this permanent? So I dont have to change the size every time I start autocad.
Old 08-23-2008, 03:03 PM
LeeWay's Avatar
LeeWay is on a distinguished road
I think you should be able to save templates. I know I can do that in TurboCad. Then just open that template for all new drawings.
Lee
Old 08-23-2008, 06:33 PM
ger21's Avatar
Lee is correct, you need to set up a template and start each drawing with that template. Start with a blank drawing, and change all the settings to how you want them (as well as layers, dimension styles, fonts......) and save as a template.
Old 08-25-2008, 07:26 PM
Saving as a template
Thanks again guys. Saving as a template worked. Thank god for "CNC ZONE".
Thank you guys too!!
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Autocad 2000 Move N4NV Autodesk Software (Autocad, Inventor etc) 3 08-13-2006 04:52 PM
changing the background of AutoCad 2002 skykash2000 Test Forum 0 09-11-2005 05:29 AM
point data in autocad trubleshtr General CAM Discussion 3 03-11-2005 05:32 AM
AutoCad 2000 DXF Question Holmes_ca Autodesk Software (Autocad, Inventor etc) 8 01-19-2005 05:50 PM
AutoCad 2000 Missing .dll file E-Stop Autodesk Software (Autocad, Inventor etc) 12 05-30-2003 11:43 AM
