Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 06-24-2008, 10:03 AM
1cnchogger is on a distinguished road
inventor question on spreadsheet
I'm new to inventor software. I am able to link od and id dimensions in my excel spreadsheet. It enables me to do multiple scaled dwgs with the same drawing. However, when I try and link my Bolt hole circle or Pitch diameter circle and number of holes it won't allow me. Stays red. Does anyone know how to do this? It would be much appreciated. Don't have much hair left to pull out. Thanks
Old 07-13-2008, 10:15 PM
esmall is on a distinguished road
Inventor Answers
Typically you need to have the correct units selected (in, mm, ul, deg) in order to get correct referencing.
What Inventor version are you using?
Can you post your shread sheet and the part file you are working on? I should be able to diagnose your issue. Or sent me the files
esmall@pcidesign.com
Eric
Inserting an excell spreadsheet smoa1980 Mastercam 10 05-13-2006 11:11 PM
DesignMax CNC Calculations Spreadsheet Torqued_AL Mechanical Calculations/Engineering Design 1 11-15-2005 06:54 AM
Gear ratio calculation spreadsheet Splint CNCzone Club House 0 07-09-2005 10:49 AM
High Speed Spreadsheet MachineSMM Hard and High Speed Machining 15 07-20-2004 04:41 PM
Metric Change Gear Combinations by J.W. Early Excel Spreadsheet CNCadmin Machine Problems, Solutions , Wireless DNC, serial port 0 05-26-2003 03:17 PM
