Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 06-13-2008, 09:01 PM
jorgeneo560 is on a distinguished road
Auto cad 3d draw to g-code
Im tired of googling and didnt found anything usefull, all software convert 2d draws to g-code, but i didnt found any program that do the same but with 3d draws, any way, i am new, i build a cnc machine, but the i cant belive that dosent exist any plug-in or soft that converts a 3d draw to g code, i need to know whow to do that, becouse i had to program a controll software for my cnc, so i need to convert the draw to g code, i am thinking that i am going to be forced to program a draw suit
Old 06-14-2008, 03:13 PM
ger21's Avatar
you'll need to export an .stl, but look at www.meshcam.com or Cut3D at www.vectric.com
Old 07-29-2008, 09:06 PM
cut3d appears to be usefull, but, i dont know if i put something bad or something like that, becouse i draw a triangle in autocad 07 in 3d mode, an small entity, 10 cm x 10cm, and when i exported to a stl and loaded into cut 3d has askme a lot of thing, i think that i culdent be grong in the things that i chosee, becose was things like center position to start, material and stuff like that, but when i was reaching to the final steps, i played the toolpath and draw a triangule but with squares, one square upon an other, like a maya piramide (i dont know whow to say that in english :P), and i couldnt test the meshcam becouse my test time passed before i culd test it, what software are the best for autocad 3d to g-code?, i am downloading the autodesk inventor 11 with the espirit or something like that, the say me that espirit cam program could pick autodesk inventor draws!, i hope that i could export that drawings with spirit, becouse autodesk inventor is an amazing cad program, the best i has seen so far
Old 07-30-2008, 09:39 AM
Tony Mac is on a distinguished road
Hello Jorgen,
Thank you for taking the time to review Cut3D - After reading your comments I'm not sure what problems you are seeing when using your sample stl file. Can you post more details or email the file to me - info (at) vectric (dot) com.
Tony
Old 08-03-2008, 12:07 AM
judleroy's Avatar
judleroy is on a distinguished road
i think the little squares you are seeing is the path the tool is taking
to approximate the shape of the triangle. you don't always cut an object in the same shape you see it. the squares are probably linked
one layer at a time and as the tool follows the path it creates the object by removing the material around leaving just the "triangle"
or i think you mean pyramid.
Old 08-03-2008, 12:27 AM
*Registered*
Mike Stevenson is on a distinguished road
Post your geometry (3D) file here for help.
Draw G-Code by Hand (Interested) ?? Switcher Visual Basic 63 06-23-2009 01:20 PM
Draw TRUMPF TC5000R NC CODE IN AUTOCAD Hodge Post Processor Files 3 07-17-2008 07:37 AM
draw and machine mike46 Alibre Design 8 12-21-2007 08:36 AM
When I hit "Cut Auto" the code generates seanreit BobCad-Cam 0 11-27-2007 07:05 PM
Draw This...I dare you! (or help me) robinsoncr Rhino 3D 5 09-17-2006 08:38 AM
