| Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here. |
I have not found a procedure to control printer output size. I'd like to use inventor (9) to create output to burn images for etching Printed Circuit boards. I can create the drawings but I'd like the capability to "control" the output (increase/decrease) by an amount (say by percent). After looking through help and several books I've been unsuccessful. I doubt that I am the only person who has ever desired to do this. Gord |
I learned to make drawings by starting off in "standard.ipt" file. I looked and this seems to be the reason that I cannot output to IDW as suggested. Is that the key issue? If so I didn't see any easy conversion to IDW format. (Needless to say redrawing wasn't in my planning <g>) Gord |
| .IDWs are basically Inventor's "paper" output. An .IDW will allow you to produce a 2d image of the part (.ipt) you have modeled. Under the file menu select new, select one of the canned .IDW templates and insert a view of your part. Change paper size, dimension, annotate, etc and your all set. Maybe post your .Ipt and I could help more. |
| Tags |
| inventor, printer, scale output |
| scaling | reedmiles | Haas Mills | 1 | 02-28-2008 09:11 AM |
| Newbie- scaling? | BiggerHammer | Hobby Discussion | 2 | 02-20-2008 09:40 AM |
| scaling parts with inventor | Shizzlemah | Autodesk Software (Autocad, Inventor etc) | 0 | 11-07-2006 09:11 AM |
| Communications output to Printer Port | kheri | Post Processors for MC | 0 | 03-26-2005 12:40 AM |
| Scaling? | Ken_Shea | OneCNC | 5 | 05-13-2003 11:58 AM |
