Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 04-29-2008, 01:22 AM
bennett71 is on a distinguished road
Converting splines to arcs
Does anyone know if its possible to convert splines to arcs in Auto cad or any other program? I am using Meta cam (mc diamond soft) for laser tooling & this program does not like splines. Any help would be greatly appreciated.
Old 04-29-2008, 06:01 AM
ger21's Avatar
Use one of the free spline to polyline lisps. Then, using pedit, use the fit option which will fit arc segments to the polyline. Explode into arcs, and if you need a polyline, you can use pedit again to join it back into a polyline composed of the arcs.
Old 04-29-2008, 12:12 PM
Gerry,
Thanks for the tip, I will try it out. I also stumbled on the wmfout/wmfin command. This converts to windows metafile & with wmfin the splines are imported as polys. I will try it tonight & see how it works.
Old 04-29-2008, 12:37 PM
ger21's Avatar
Saving as .v12 .dxf will do the same thing. Just save as v12 .dxf, close the drawing, and open the .dxf.
Old 05-02-2008, 01:19 PM
josteurs is on a distinguished road
True, you can "save as" your autocad as an pre release 12 version which wil than change your spline into line and arc segments. newer CNC software usualy don't have a problem with splines
Old 10-11-2011, 07:47 AM
klrskies is on a distinguished road
Im useing Mechanical 2010. Thanks for the tip! When I use the v12.dxf save, and get a 3d polyline, its broken into many, many tiny line segments. Can I convert it into a lower resolution group of lines and or better yet, arcs so I dont have so many entities?
Old 10-26-2011, 05:10 PM
JMaeding is on a distinguished road
note that the flatten command converts splines to plines, its not documented but works. Flatten also sets z coordinate vals to 0 so watch what you are doing.
Where are my splines? PhillyCyberJoe Solidworks 2 01-04-2008 10:59 AM
I can't get rid of splines!! dan3676 General CAM Discussion 1 09-21-2006 09:57 AM
Splines spalm SheetCam 14 02-18-2006 06:26 PM
Splines dneisler General Metalwork Discussion 3 11-30-2005 09:03 PM
Help with splines CNCRob Autodesk Software (Autocad, Inventor etc) 2 09-03-2005 03:14 PM
