Results 1 to 8 of 8
Thread: Thermwood and AutoCAD
    Apr 2008
    UK
    Angry Thermwood and AutoCAD
    Hi, I am trying to get our Thermwood C67 5 Axis Router to accept .DXF files.
    In the manual it says it is possible to draw a shape in AutoCAD and have a line of code over the start point on each entity, so you can change the feed rate, depth, etc.
    I have attached the .DXF file from AutoCAD and the G-code file from the CNC.
    Is it not working because of the font im using? It asks for a mono-spaced font, we have tried loads of different fonts.
    Thanks for you Help
    Martyn
    Attached Files Attached Files
    Mar 2003
    Shelby Twp, MI....USA
    Fonts will probably need to be exploded using Express Tools.
    Apr 2008
    UK
    Thanks for the idea. It didnt work tho.
    Anyone else got any ideas.
    Its driving me mad, ive tried everything
    Martyn
    Registered zimcad svc's Avatar
    Feb 2005
    If using AutoCAD 2004 try saving as an earlier release like R14 .dxf ? or even a 2000 .dxf ?
    Apr 2008
    UK
    Just Tried that, it didnt work.
    I think im going to have to phone Thermwood in USA.
    Anyone else tried anything like this?
    Mar 2006
    try = (start)
    works on mine.
    Jan 2007
    Hamilton,Oh
    There are levels when exploding certain things like multi-line text. I downloaded your DXF and the first time I explode your MULTI-LINE TEXT it becomes TEXT, the second time I explode the same selection it becomes GROUP OF GRAPHICS, the third time I explode the selection it becomes several POLYLINES, and I explode it even twice more after that to finally get it to a bunch of LINE(s).
    I've used many DXF to G-code converters, even wrote one myself and a few can read polylines and some can only read lines (not polylines).
    Give this a try, I believe it will work although I'm not familiar with Thermwood.
    Mar 2003
    Quote Originally Posted by bborb View Post
    In AutoCAD, you can only explode text with the explode text express tool, and you should only need to do it once. This will get you polylines, though. If you need regular lines, use the regular explode command on the polyline text.
    1. Used thermwood parts
      By zachf in forum CNC Machining Centers
      Last Post: 09-27-2011, 08:27 AM
    2. Thermwood cnc?
      By tim in pa in forum Commercial CNC Wood Routers
      Last Post: 06-14-2011, 01:56 PM
    3. Thermwood C50
      By Jamesgang in forum Commercial CNC Wood Routers
      Last Post: 08-28-2007, 04:24 PM
    4. My New Thermwood
      By Taz in forum WoodWorking
      Last Post: 03-31-2006, 06:58 PM
    5. Post for Thermwood
      By MegaMoog in forum General CAM Discussion
      Last Post: 01-20-2005, 03:03 PM
