Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 03-19-2008, 10:22 PM
DeviousMW is on a distinguished road
Need some autocad help
Hiya,
I am a long time cnczone member.. I need to have a part made by a manufacturer but I need to create an Autocad 12 compitable dxf file so it works with their cnc laser equipment.
Anyone want to help out a part time cncguy? I cant afford a lot but I can pay for a decent dinner or two. Its essentially a rectangle with rounded corners, and 4 1.3" slots cut near the 4 corners. I can give you exact dimensions, measurements, and a rough drawing. Once the cad drawing is done, I need the dimension changed 12 times to make 12 different sizes and dxf files of the same design.
Can anyone help me out?
I have zero CAD skills
Thanks,
DeviousMW
Old 03-19-2008, 11:21 PM
Al_The_Man's Avatar
I have AutoCad12, if it is not too time consuming I could look at it for you, you can PM me the diag.
Old 03-20-2008, 08:09 AM
ger21's Avatar
Post a sketch or something, and I'll take a look at it.
Old 03-20-2008, 01:11 PM
Mad Drafter is on a distinguished road
Sounds easy enough for what you are looking for. I would be glad to help but need dimensions. Shouldn't take more than few minutes to draw up.
Old 04-05-2008, 04:20 PM
kthomson is on a distinguished road
If this hasn't already been addressed, send me the specs and I'll look at it (no dinners necessary, but a 6 pack might be good <G>). It should just be a matter of creating one drawing and scaling copies for the other sizes.
Old 04-05-2008, 05:48 PM
Al_The_Man's Avatar
I already sent them, but I have not heard back if they worked OK.
Old 08-01-2011, 05:18 AM
adithyan is on a distinguished road
how to do pocketing
How to generate pocket-milling/raster G-code from a vector shape/polyline.
autocad m!ni Autodesk Software (Autocad, Inventor etc) 5 10-27-2006 06:42 AM
autocad to pdf andyinmo Autodesk Software (Autocad, Inventor etc) 15 07-18-2006 06:58 AM
AutoCAD Now what? MBG Autodesk Software (Autocad, Inventor etc) 5 07-06-2006 02:04 AM
AutoCAD MBG Autodesk Software (Autocad, Inventor etc) 7 06-04-2006 07:46 PM
Autocad LT verse AutoCad LT CNCadmin Autodesk Software (Autocad, Inventor etc) 2 02-03-2004 07:28 AM
