I use AutoCAD 2000i with RouterCim every time I turn on RouterCim on, the OSNAP turns off and also when I go back and forth from the tooling page it also turns off? Is there a way to keep this on?
The AutoSnap markers, tooltips, and magnet are turned on by default. You can change AutoSnap settings in the Options dialog box.
In addition once you have all the settings to your liking, try a right click on the drawing window, choose the profile tab and save your profile with your settings. Use the help and do a search on default profile for more specific info.
Hope this helps
-Marc
