Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 03-15-2008, 08:44 AM
PeteGallo is on a distinguished road
Unable to extrude along path
I am not able to choose an arced cylinder as a path to extrude a box.
Attached are the entities I am working with.
Old 03-15-2008, 08:56 AM
cam1 is on a distinguished road
If you generated the arced cylinder using a sweep, try using the path (line) that you used to generate that feature.Most extrude along path functions require a line or an edge.
hope this helps
Old 03-15-2008, 09:43 AM
Hi cam1,
Unfortunately I no longer have the path arc (sweep) used to extrude the cylinder along. I deleted it after creating the cylinder.
Is there any method to great an arc duplicating the extruded cylinder.
Thank You,
Pete Gallo
Old 03-15-2008, 11:23 AM
ger21's Avatar
Originally Posted by PeteGallo View Post
Hi cam1,
Thank You,
Pete Gallo
Not easily. How did you draw the path in the first place so that you can't duplicate it? You can probably get it close by "tracing" it in a side view.
Old 03-15-2008, 11:38 AM
Try this:
Use the plane that runs through the CL of the swept cylinder to create a new sketch.Project one of the cylinder edges onto that sketch,(then turn into construction geometry) Use an offset sketch command to generate a new CL on that sketch plane. Then use that new line as the path....worth a try
regards
Old 03-15-2008, 11:44 AM
Hi ger21,
Originally I created a circle then kept the arc portion required.
I guess if this is the only way I'd better get to it.
Thanks for your help guys at least I wont feel their's a better way and I'm wasting my time.
Thank You
Pete Gallo
Old 03-15-2008, 12:13 PM
ger21's Avatar
Originally Posted by cam1 View Post
Try this:
regards
I think he's using ProgeCAD and doesn't have any (or most) of those options.
Old 03-15-2008, 12:28 PM
Hi Gerry, to bad....I thought he's using Inventor
regards
Old 03-15-2008, 02:10 PM
Good memory Gerry yes I am using ProgeCad.
I did find an offset parallel command but nothing for sketch.
I realized if I could extrude the arced cylinder along the Y Axis I could create the entity I'm looking for. But I'm not able to do this with this entity, what differs in this entity that does not allow these type of manipulation.
Thank You
Pete Gallo
Old 03-15-2008, 02:16 PM
ger21's Avatar
Only certain entities can be used for the path. The help file should tell you which ones.
extrude from planar curve smoker Rhino 3D 3 03-21-2007 05:50 PM
unable to upload DXF file Al_The_Man Forum Questions or Problems 2 12-24-2004 09:24 PM
