Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 02-23-2008, 01:33 PM
SPEEDRE is on a distinguished road
How To Make Changes
How can I change the font used in a drawing permanently. I don't like the funky techy type now used as default. I must change it every time I make a dwg., want to change the default to a new standard font.
Old 02-23-2008, 03:20 PM
cam1 is on a distinguished road
Hi:
Open a new part file
Under the top menu you will see a properties folder.(probably tools, options)
Change the fonts, units grid etc to your liking
Save the file (not as a part file, but as a part template in the template directory.(scroll down the file options list when you do a save as)
Now whenever you select that template that file will open, with the options you set.
It's been a while since using Inventor, but that's the basic principle.
regards
PS use the Help function to guide you.
Old 02-24-2008, 08:12 AM
Thanks. I forgot that I could save it. I've got AC 2000 at home and usually don't need to do that, anyway Thank you sir!
Old 02-24-2008, 03:26 PM
Cheers
What do you make and How do you make it??? cyclotron CNCzone Club House 1 03-23-2012 02:18 AM
What can I make With this? Siren Joes CNC Model 2006 1 08-16-2007 05:23 AM
trying to make a die. Dougotio Diemaking and Diecutting 9 04-08-2006 05:37 PM
CNC able to make this? kentrob11 Hobby Discussion 92 03-09-2006 08:30 AM
How can I make cncman General Electronics Discussion 3 03-23-2004 01:49 PM
