Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 01-31-2008, 11:31 AM
cxixer is on a distinguished road
Ovals!
Is there a way to save or export ovals with AutoCAD that will cut as true arcs instead of a bunch of line segments? I have cut circles using those little lines and they do not come out very nice. I can sand the little bumps down if I must, but I prefer them to cut as true arcs in the first place.
I'm using LazyCAM 2.0 to convert the dxf to gcode.
Thanks!
Old 01-31-2008, 05:15 PM
ger21's Avatar
If you mean ellipses, then type PELLIPSE and change the value to 1 before drawing the ellipse. It will now be made up of arcs.
It will deviate slightly from a true ellipse, though, because you can't draw a true ellipse with arcs.
Old 01-31-2008, 06:32 PM
As long as it's better than what I can do by hand. Thanks, I'll give that a try.
Kcam not seeing ovals properly monkamarm2000 General CNC (Mill and Lathe) Control Software (NC) 9 06-30-2005 02:40 PM
