Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 11-20-2007, 05:18 PM
phil m is on a distinguished road
Converting ACAD DWG into Inventor Part file
I'd like to take a 2D drawing from AutoCAD and use it for a sketch in a part file in Inventor. Is there a way to do this? Whenever I try to import it to Inventor it just opens up as a drawing.
Old 11-20-2007, 06:22 PM
*Registered*
Rube is on a distinguished road
open the 2D autocad drawing,
select all the entities you want to copy,
use "Edit...Copy With Basepoint" select a basepoint
Then in the inventor sketch environment simply "paste"
Be aware that none of the constraints will come over with the 2d info however.
Old 11-21-2007, 12:03 PM
neilw20's Avatar
neilw20 is on a distinguished road
Question Do you need 3D?
If you need 3D in inventor, maybe you can extrude or rotate the 2D shape, then cut and paste, using Copy with basepoint to get it into Inventor.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Mach3 shape file to ACAD vmax549 Autodesk Software (Autocad, Inventor etc) 7 11-20-2007 12:23 PM
Converting SolidWorks to ACAD ImanCarrot Solidworks 5 11-15-2007 08:08 AM
Converting a File Tazzer ArtCam Pro 0 10-30-2005 04:52 PM
Inventor Part Files vladdy Autodesk Software (Autocad, Inventor etc) 0 04-03-2005 09:59 PM
Converting a .max file DAB_Design General CAM Discussion 5 01-28-2005 01:00 PM
