Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 09-29-2007, 12:21 PM
mark c's Avatar
mark c is on a distinguished road
no text?
I'm having problems at work with my Inventor 8. I'm a CNC programmer and use it to design fixtures and the like. The design group used to use it, but they have switched over to Solidworks, and they've kinda forgotten the setup type issues that I'm sure is causing my problem, ie: I can't insert text into my idw file. I can't do it by selecting the text tool or even by adding text to an existing dimension.
I've looked at the configuration menus and I don't see anything wrong, but I'm new to Inventor, just been using it on an existing installation. One of the engineers did look at it and didn't see anything wrong. It did work at one time. I'm not sure what changed.
Anyone got any ideas about what to check? I even did an re-install over itself to repair any problems, but that did nothing
Thanks in advance
Mark
Insanity "doing the same thing and expecting a different result"
Mark
www.mcoates.com
Old 12-07-2007, 07:06 PM
MarkWink is on a distinguished road
...a Microsoft Patch took out the text, Autodesk has patches, although ver 8 may not be supported, you'll need to replace the riched20.dll in the /bin folder
let me know I have the .dll
Old 12-10-2007, 02:05 PM
mark c's Avatar
I checked at the Autodesk site and you're right, V8 is not supported. I found a riched20.dll on the web and put it in the bin folder but that didn't work. Could you PM me the dll please?
Thank you
Mark
www.mcoates.com
text to cnc program rhino General CNC (Mill and Lathe) Control Software (NC) 1 02-04-2009 07:28 AM
3D text Deco_2000 SolidEdge 4 10-11-2007 03:23 PM
text marty7001 BobCad-Cam 2 05-31-2007 02:26 PM
Need Text Help becikeja BobCad-Cam 14 11-11-2006 11:54 PM
Text Bigfoot1 OneCNC 1 04-04-2003 09:06 PM
