Results 1 to 3 of 3
Thread: retrieving files?
    Jul 2006
    retrieving files?
    this maybe over before it began. i had not yet saved a drawing that i was working on and the power went out. is there a temp file somewhere that it can be retireved from?
    i know i know always save as i go. battery backup. etc. oops my mistake.
    thanks
    bear
    Sep 2005
    if autosave is turned on, yes.... look in your config options, and it will show
    you the directory. the files will be called xxxx.sv$ I believe, all you do is rename it .dwg and your in, at least up to your last save or autosave..
    Set autosave to every 5 or 10 minutes if you want a lot of safety....
    Jul 2006
    thank you so much!
    bear
  1. I don't see any files?
    By borrisl in forum Post Processor Files
    Last Post: 06-21-2006, 12:48 PM
  2. ncp files to dxf or dwg
    By greenmanor in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 10-26-2005, 11:33 PM
  3. Retrieving Stepper Motors
    By andy_ck87028 in forum Stepper Motors and Drives
    Last Post: 10-25-2005, 05:42 PM
  4. DXF files???
    By f.100 in forum General CAM Discussion
    Last Post: 02-10-2005, 11:33 PM
  5. DXF or PLT files
    By signIT in forum DIY CNC Router Table Machines
    Last Post: 07-01-2004, 05:57 PM
