Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 06-17-2007, 08:32 AM
M-man is on a distinguished road
UNwrap OD surface of ppe
Ive got a solid of a pipe with differents cut, that I would want to get the OD surface "unwrapped". Is this possible on acad or must I use somekind of sheet program? COuld someone help me if I provide the solid?
Old 06-17-2007, 09:49 AM
ger21's Avatar
AutoCAD won't unwrap it for you, but you could draw an unwrapped version if you you're good.
This might be of interest, but may not be much help.
http://www.tamasoft.co.jp/pepakura-en/
Old 06-17-2007, 10:09 AM
Any other cad that can do this?
Old 06-19-2007, 09:00 AM
laserboy is on a distinguished road
solid works will do it, in most cases. aslong as you know where the split line and diameter of part.
Old 06-27-2007, 01:42 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Inventor will unwrap also.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Countersunk Surface Rally Mastercam 11 05-25-2007 02:16 PM
unwrap cylinder to engrave on o/d Capt Crunch Mastercam 5 04-22-2007 07:18 PM
MDT 6 Surface Cut djzepp Autodesk Software (Autocad, Inventor etc) 0 04-10-2007 10:56 PM
could you check my surface. corrie Rhino 3D 12 04-08-2006 08:35 PM
3D wireframe surface JW Peters Autodesk Software (Autocad, Inventor etc) 3 05-09-2005 07:23 PM
