Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 05-21-2007, 05:55 AM
acidcustom is on a distinguished road
offsets for tool paths
Is there anyway Autocad can draw offsets for perimeter and islands to use for toolpaths
thanx
Old 05-21-2007, 06:57 AM
Alfonzo is on a distinguished road
Use the offset command? Or isn't it that simple?
Old 05-21-2007, 07:11 AM
duramax_railbuff is on a distinguished road
The 'Offset' command can be initiated by means of an icon, or by typing 'o' on the command line. You can specify the amount of offset, then apply it to the objects. If for instance you are offsetting a rectangle either internally or externally, the offset lines will either overlap or not quite meet. Use the 'Fillet' commanf 'f' on the command line, with the radius set to what ever you had the offset set to.
Hope that helps.
Old 05-21-2007, 07:24 AM
celtic-mfg is on a distinguished road
Offsetting a tool path
I have used AutoCAD to create a tool offset for mills and waterjets.
If you take your existing tool path and convert it to a polyline, you can then offset the entire tool path at one time without having to fillet the individual line segments. Most CAM systems require you to explode the polyline back to lines and arcs to read properly. If you need help with the AutoCAD commands to make and explode polylines, let me know and I'll post those separately. Mark Runnels
Old 05-21-2007, 09:08 AM
M Burge is on a distinguished road
Set up a layer called, for instance "Cutter Line offset", use this layer to offset the construction line by the radius of your cutter tool. Using a separate layer for the cutter line which can be switched off will not affect the appearance or complicate your original drawing.
Old 05-21-2007, 12:17 PM
edward12 is on a distinguished road
what would you like to see in the perfect cnc programming system?
Old 05-21-2007, 12:18 PM
tporter is on a distinguished road
How do you convert a drawing to polylines in Ver 2000? I have to redraw
when ever I want all polyline. Thanks
tporter
Old 05-21-2007, 12:26 PM
Bubba's Avatar
Bubba is on a distinguished road
t,
you can use pedit, and then join and it will ask you if you want to convert to a polyline. alternatively, you can use express tools >Modify>polyline join and it will do it for you. Just keep clicking on the lines you want to join. Obviously, all lines to be joined must meet at their end points and have no gaps or overlaps or it wont work.
Art
Old 05-21-2007, 12:30 PM
ger21's Avatar
Select the lines and type PEDIT. It will ask if you want to convert them to polylines.
Old 05-21-2007, 05:22 PM
mxylplix is on a distinguished road
I think you can use the mpedit command also which allows you to select more than one line.
  #11   Ban this user!
Old 05-21-2007, 08:22 PM
BMG BMG is offline
BMG is on a distinguished road
Procedure
Paranthese indicate what to type
Type (PEDIT)
Select a single part of the line you wish to assemble
Hit ENTER
IF it asks if you wish to make it a Polyline - type (Y)es
-----assemble parts-------
with Pedit active, type (J)oin
type (ALL) to select everything in drawing - Only segments where the endpoints meet will be joined
Hit ENTER
Hit Enter Again
------Offsetting ------
Select assembled Polyline
Type (OFFSET)
state offset distance at prompt
Select side of object you wish to offset too
Hit ENTER to end command
-----Disassembling parts -------
Select offsetted line
Type e(X)plode
Offsetted polyline is now arcs and lines
If you have a relatively small drawing, the all selection is not an issue. If someone gave you the drawing and they are sloppy, you could have problems with the join function in the PEDIT command.
Also, PEDIT joins must all have the same Z elevation.
Hope that helps.
  #12   Ban this user!
Old 05-22-2007, 12:32 AM
sinha_nsit is on a distinguished road
After you have converted your sketch into one polyline, and then drew the offset curve (offset diatance being equal to tool's radius), you can extract information (such as coordinate values of start/end points, radii of arcs etc.) about the offset curve through PROPERTIES command, which you can now use in your CNC program.
S.K.Sinha
Laser tool paths CNCadmin SheetCam 7 07-18-2005 12:47 AM
Rotary tool paths DAB_Design Mastercam 1 03-31-2005 01:27 PM
3d tool paths ginamc OneCNC 5 03-19-2005 11:17 AM
xp custom tool paths Mortek OneCNC 20 06-29-2003 05:28 AM
Tool Paths WOODKNACK G-Code Programing 7 04-26-2003 08:09 PM
