| Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here. |
Hello, I have Autodesk Inventor Series 2008. I do not know how to convert a customer's IGES file into DXF using the Autodesk inventor Series 11. I had to use a friend's TurboCad Professional version 12 to open the IGES and then save it as DXF, but find that the arcs on the IGES file are small lines instead. Does anyone know how to convert an IGES file into DXF using Autodesk? Thanks in advance. |
| *bump* I need this too please- well, actualy I need to convert IGS/ IGES files into ACAD files- I know there are commercialy available add ons for ACAD to do this, but are there any free applications to do it please (I have searched, beleive me- hence the reason to bump rather than start a new thread. Many thanks in advance.
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
| DXF is flat 2D data IGES is a 3D package you can't convert 3D data into DXF format but maybe you can convert to a native Autocad doc. file instead. By the way if you are running Autocad I feel sorry for you!
__________________ Be carefull what you wish for, you might get it. |
| You might try importing the IGES file in to Inventor. Then create a drawing file with the various views you want of the 3D file. Export the drawing file as a DXF. This is basically how I have done it in the past using ProEngineer and Unigraphics NX. |
.dxf can contain 3D meshes, polygons and solids and any other 3D entities that AutoCAD can produce. It's just an open ascii format of the AutoCAD .dwg format. It's not limited to 2D data.
I use Rhino to generate a flat pattern from a 3D IGS file. It has a a feature called "Unroll developable surface" that takes a 3D surface of a model in any orientation and lays it flat at 0,0,0. |
| dxf to iges | biancocat | BobCad-Cam | 3 | 04-18-2008 03:03 PM |
| BobCad to iges | diemaker | BobCad-Cam | 2 | 11-02-2006 07:30 PM |
| IGES to CAMWARE | Nous19 | Mazak, Mitsubishi, Mazatrol | 1 | 06-10-2006 01:45 AM |
| 3d DXF to IGES/STEP | Neil_J | General CAM Discussion | 2 | 01-22-2006 04:01 PM |
| .iges to .dwg | haashrt310 | Autodesk Software (Autocad, Inventor etc) | 8 | 09-17-2003 01:40 PM |
