Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Autodesk Software (Autocad, Inventor etc)
Autodesk Software (Autocad, Inventor etc) Discuss Autodesk Software (Autocad, Inventor etc) software here.
Old 05-13-2007, 10:11 AM
mcyr is on a distinguished road
Acad 2000 Solids Manipulation Question
Is there a way to create a solid model of something in Acad 2000 with different regions/profiles at opposite faces of a box? The regions would have different sizes and profiles and possibly not be symmetric on the two faces of the box.
For example, I've tried looking at this like a hot wire foam cutting solution: Imprinting 2 different airfoils on opposite faces of solid box and then trying Boolean operations to leave just the solid wing, much like a core left after foam cutting. Am I doing something wrong or is there a simpler way to accomplish this task? I'd even settle for the hard way to do it if someone could describe the process.
Thanks for any help anyone can provide.
Mike
Old 05-13-2007, 10:20 AM
ger21's Avatar
I don't think there's an easy way to do it in 2000. In 2007 you can loft it, but not earlier versions. I'd use meshes, and download a mesh to solid lisp to convert it to a solid. You may have to do it in 2 halves and union them after. Also, it will have a faceted surface like a mesh, but if you use high res meshes it mike be acceptable for what you're doing.
Old 05-13-2007, 10:33 AM
Thanks, Ger! Could you point me in the direction of where the LISP converters are? Can you tell I'm a noob at this???
Thanks again.
Mike
Old 05-13-2007, 10:38 AM
ger21's Avatar
http://www.cadforum.cz/cadforum_en/tips.asp?t=m2s
http://www.accustudio.com/marketplace/freeware.htm
http://discussion.autodesk.com/threa...hreadID=469691
Old 05-13-2007, 03:01 PM
Thanks again, Ger. I found the M2S lisp and it worked well. This route is so much easier than what I was trying to do!!!
Mike
Acad 07 to mastercamX Demon440 Mastercam 3 01-04-2007 09:04 AM
Solids Question? Al_The_Man Autodesk Software (Autocad, Inventor etc) 8 03-25-2006 09:24 AM
Solids question trevorhinze BobCad-Cam 2 12-10-2005 11:59 PM
AutoCad 2000 DXF Question Holmes_ca Autodesk Software (Autocad, Inventor etc) 8 01-19-2005 05:50 PM
how do i get my cnc to cut my acad dwg? ljoe1969 Autodesk Software (Autocad, Inventor etc) 6 11-05-2003 10:05 AM
