Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: solids
    Registered balsaman's Avatar
    Mar 2003
    solids
    Ok I am fairly good at 2d drawings in Autocad. How can I convert a 2d object into a surface so I can extrude it into a 3D solid object?
    I use Autocad 2000i. I also have mech. desktop but never used it.
    Thanks!
    Eric
    I wish it wouldn't crash.
    Mar 2003
    Any 2D object that has closed boundries should be able to be extruded. It doesn't have to be converted to a surface.
    Site Owner CNCadmin's Avatar
    Mar 2003
    Or use Pedit and convert all the lines to a close polyline. Than you can extrude it. In MD, you have a little more steps to make a part, but you can draw in it like you would autocad. I have allot of exsperance with MD.
    Thank You,
    Paul G
    Site Owner-Webmaster-
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Mar 2003
    Hey guys, you are correct! I just extruded some stuff! I guess I should have tried it. I just assumed it was harder than that.
    Eric
    Apr 2003
    It is much easier to use "boundary", then click inside the part. It will search out the edges, and draw a pline all the way around. If the part is not closed, it will fail.
    Then you can just extrude the new pline.
    Many of my 3d parts start with a bunch of xlines, then a single boundary command to make the outline.
    Zeph
    Mar 2003
    I'll have to try that, I usually use the pedit command. Or I redraw using a polyline.
    Thank You,
    Paul G
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Apr 2003
    Houston
    Hello all,
    I work in the world of 3D all day long and I thought I knew all the tricks but the boundary command is one that I have not used in my work, I design brine water plants. Thaks guys.
    Eric
    OBTW this is what I do as part of my hobby of model airplanes...
    Apr 2003
    Houston
    Oops the picture did not go????
    sorry guys I could not get the picture small enough.
    Eric
    Mar 2003
    Eric
    Try this - http://cnczone.com/showthread.php?s=&threadid=210
    Thank You,
    Paul G
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Apr 2003
    Boundary is great if the view port is normal to the working plane. It can do some weird things when you have lines at various Z levels too. There are still times where I give up trying to determine what it is doing, and sketch in a pline using the osnaps.
    Zeph
    Apr 2003
    Houston
    Thank you CNCadmin,
    I downloaded the viewer and have resized it to a much smaller size.
    Hope this works.
    On the subject of solids, I have found that connect all the lines needed to make a region and then go to propertied and set all z coordinates for the potential region to 0 and then region it then extrude it. it seems long but it never fails.
    Eric
    Mar 2003
    Nice AirX!
    I made a 3d part! Thanks guys. Still lots to learn.
    Eric
  • Page 1 of 2 12 LastLast
    1. Converting solids, and surfaces
      By MILLMANM in forum Mastercam
      Last Post: 01-05-2005, 12:31 PM
    2. How do I create solids from lines?
      By HawainPand in forum BobCad-Cam
      Last Post: 09-12-2004, 01:36 AM
    3. solids
      By tsutt in forum Mastercam
      Last Post: 04-06-2004, 10:33 PM
    4. Important Things in 2D Milling Solids
      By Gibbsgod in forum GibbsCAM
      Last Post: 08-15-2003, 09:42 AM
    5. drawing to solids
      By georgebarr in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 07-02-2003, 09:23 AM
